Features moving on pan
906
03-07-2013 07:05 AM
FaizanTayyab
I have a feed that i am loading in from an external source and it working well. However i have just noticed that when i pan the map, the features drawn are moving as the map moves, it ends up with looking bad.
While looping through the feed source, i am getting all the data and adding graphics dynamically to a graphic layer which after the loop i am adding to the map. Works fine.
However as described above the pan causes the feed graphics to move or feel like jumping as the background map is panned.
Any ideas on what causes this behaviour.
I am using IE8
Regards
