Hello, I have an issue with features 'flickering' in and out whilst moving the camera around in a 3D scene, when the layers have a FeatureFilter applied. The setup uses arcgis/core version 4.28.10, with a FeatureFilter being applied to OGCFeatureLayers and FeatureLayers in a WebScene.
Here's a clip of the issue;
I tried creating a mirror of the project setup with some test data in a codePen, and wasn't able to reproduce the same behaviour (maybe having more data in the layer makes the problem worse?). A similar flickering effect can happen when features overlap in 3D space (z-fighting), and when viewed from a particular angle (above or below), whether or not they have a filter on.
To test my theories I've tried the following in my project with no luck;
Any help on this would be much appreciated!
Thank you,
Chris
Hmm, really hard to say what causes this without an actual reproduction case.
Also, can you check the following:
As said, hard to say but from the current recording I would say:
