FeatureLayer with points
1118
04-25-2013 01:28 AM
CristinaJacome
Hello
I have an array of esri.Graphic:
var features = [];
//add 6000 points
            var point = new esri.geometry.Point(x, y, new esri.SpatialReference({ wkid: 102100 }));
            var symbol = new esri.symbol.SimpleMarkerSymbol().setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_DIAMOND);
            var graphic = new esri.Graphic(point, symbol);
            features.push(graphic);
Now, I want to draw all that points on a layer, only draw, without events.
How can I do?
I thought add a FeatureLayer, but I get an error:
var featureSet = new esri.tasks.FeatureSet();
featureSet.features = features;
            var featureCollection = {
                featureSet: featureSet
            try {
                var layer = new esri.layers.FeatureLayer(featureCollection);
                map.addLayer(layer);
            } catch (err) {
                alert(err.message);
Error: path is not defined.
JohnGravois
if you've already created the graphics, you should be able to pass them to the default map graphics layer using map.graphics.add(graphic)
CristinaJacome
Thank you for the reply.
The problem is that they are 6000 points. Is there another more efficient way?
Once points are added, the actions on the maps are very slow.
JohnGravois
there is more than one technique you could use to improve performance.  check out the following article on featureLayer/graphicLayer performance for a more in depth discussion.
here are a couple things to try:
1.  perhaps you could set the minScale property on the map graphics layer so that the features only draw when you're zoomed in closer?
2.  if you are working with a featureLayer from an ArcGIS Server map service, you could display the data in a dynamicMapServiceLayer instead and work with the featureLayer class in selection mode instead to query for individual geometries and attributes on the click of the map. (see sample of this in action)
