FeatureLayer with client side graphics does not show with Print widget
1003
10-16-2018 11:51 PM
MarkusÅfelt
When I took arcgisJS 4.9 into use the client-side Feature Layer printing broke down. I'm using default Print wigdet.
I have attached example code that demonstrate the problem that client-side feature layer does not show in the print.
It was working in arcgisJS 4.8.
I was debugging the problem and noticed that ExportWebMap will think it is Feature Layer and expects to have URL which it does not have, so nothing can be seen in the print.
Tried also with argcisJS 4.8 and ExportWebMap handles the FeatureLayer as client side graphics and graphics are seen in the print.
Is this a new bug in the argcisJS 4.9? or how I can fix this problem? I would like to use Print widget.
Noah-Sager
Hi Markus, this looks like a new issue at 4.9. We are currently investigating. Thank you for posting your issue.
-Noah
