FeatureLayer needs access to LayerInfos
2366
11-08-2010 06:31 PM
StephenLead
Honored Contributor
Given a REST endpoint, how can I programatically add all of the component layers to the map as FeatureLayers?
The sample at http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/map_dynamiclay... shows how to use LayerInfos to add all of the layers in the REST endpoint to the map, using setVisibleLayers in a DynamicMapService.
But I can't see a method to do the same thing using Feature Layers. How can I programatically traverse all of the layers in a Map Server REST endpoint, and add these to the map as Feature Layers?
Steve
KellyHutchins
Esri Notable Contributor
One approach would be to use esri.request then add each layer to the map:
    dojo.require('esri.layers.FeatureLayer');
      var baseURL;
      var map;
      function init() {
      var initExtent = new esri.geometry.Extent({"xmin":-8590965.388453046,"ymin":4695877.530747742,"xmax":-8553434.807565076,"ymax":4711164.936404756,"spatialReference":{"wkid":102100}});
      map = new esri.Map("map",{extent:initExtent});
      var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer");
      map.addLayer(basemap);
      baseURL = "http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/HomelandSecurity/operations/MapServer";
        esri.request({
          url:baseURL,
          content:{f:"json"},
          callbackParamName:"callback",
          load:addLayers,
          error:esriConfig.defaults.io.errorHandler
    function addLayers(response,args){
     dojo.forEach(response.layers,function(layer){
      var featureLayer = new esri.layers.FeatureLayer(baseURL + "/" + layer.id,{
          mode: esri.layers.FeatureLayer.MODE_ONDEMAND,
          outFields: ["*"]
      map.addLayer(featureLayer);
      dojo.addOnLoad(init);
KellyHutchins
      var baseURL;
      var map;
      function init() {
        esri.request({
          url:baseURL,
          content:{f:"json"},
          load:addLayers,
          outFields: ["*"]
StephenLead
Honored Contributor
Awesome, thanks once again Kelly
