FeatureLayer modes (MODE_SELECTION and MODE_ONDEMAND) for JS 4.x
3856
9
09-13-2024 10:03 AM
Mr_Kirkwood
I am new to the JS 4.x language. The JS 3.x had the modes. These helped with queries where you could zoom into a FeatureLayer  and have it turn on when zoomed to. The Featurelayer doesnt show up when using MODE_SELECTION until it was queried and selected. Here is an exapmple of the 3.x code:
floorOutline = new FeatureLayer (urlFloorOutline, {
                    mode: FeatureLayer.MODE_SELECTION,
                    outFields: ["*"],
                    opacity: 0.8,
This was added t othe map and did not show up on the map until you ran the zoom to fucntion:
function zoomFloorOutline (id)
    require ([
        "esri/tasks/query",
        "esri/geometry/ScreenPoint",
        "esri/geometry/Extent",
        "esri/layers/FeatureLayer"
            function (Query, ScreenPoint, Extent, FeatureLayer)
                console.log ("zoomFloorOutline")
                clearGraphics ();
                var query = new Query ();
                query.objectIds = [id];
                var myDate = new Date ();
                var myMS = myDate.getMilliseconds ();
                query.where = "(" + myMS + "=" + myMS + ")";
                console.log ("zoomFloorOutline + id")
                floorOutline.selectFeatures (query, FeatureLayer.SELECTION_NEW, function (features)
                    var floorExtent = features[0].geometry.getExtent ().expand (1.5);
                    map.setExtent (floorExtent);
How do i do something similar with JS 4.x?  I have some code to zoom to the feature but it is visible when the map is loaded and i just want show the quereied floor.
    require ([
        "esri/rest/query",
        "esri/rest/support/Query",
        "esri/layers/FeatureLayer",
       "esri/views/layers/LayerView"
            function (query, Query, FeatureLayer,LayerView)
                console.log ("zoomFloorOutline");
//                let highlight;
                view.whenLayerView (floorOutline).then (function (layerView)
                    var query = floorOutline.createQuery ();
                    query.where = "1=1";
                    floorOutline.queryFeatures (query).then (function (results)
                        const features = results.features;
                        console.log("zoom Floor" + features)
                        var geometry = features[0].geometry.extent.clone ().expand (2);
                        view.goTo (geometry);
Thanks for any help.
2 Solutions
JoelBennett
MVP Regular Contributor
On line 25 of your 4.x code you have this to zoom to the feature:
If you want to make the layer visible after zooming, you can change that line to the following:
view.goTo(geometry).then(function() {
	floorOutline.visible = true;
JoelBennett
On line 21, instead of:
I think you need this instead:
query.where = roomsUseLayer.definitionExpression;
Or better yet, you could remove line 21 altogether, because according to the documentation for createQuery, the "where" setting should already be set according to the definitionExpression.  Setting it to "1=1" would overwrite that and return all features in the layer.
JoelBennett
If you're just wanting to show a particular set of features at any given time, and know the objectID values of that set, then using definitionExpression would be one way to do so:
function hideLayerFeatures(featureLayer) {
	featureLayer.definitionExpression = "1=0";
function showLayerFeatures(featureLayer, ids) {
	if (Array.isArray(ids))
		featureLayer.definitionExpression = featureLayer.objectIdField + " IN(" + ids.join(",") + ")";
	else if (typeof ids == "number")
		featureLayer.definitionExpression = featureLayer.objectIdField + " = " + ids.toString();
Mr_Kirkwood
I already have some code to grab the OBJECTID. How do I get the layer to turn on to the queried OBJECTID when I zoom to the Feature? I have set the visibility for the whole layer to "false"
JoelBennett
Mr_Kirkwood
That worked. Thank you so much for your help.
Mr_Kirkwood
Thanks again. Here is my updated code snippet:
    require ([
        "esri/rest/query",
            function (query, Query, FeatureLayer, LayerView)
                floorOutline.definitionExpression = floorOutline.objectIdField + " = " + id.toString ();
                console.log (floorOutline.definitionExpression)
                        view.goTo (geometry).then (function ()
How would this work with an array of OBJECTIDs? My JS 3.x looks like this:
function zoomRoomUse (ids)
    require ([
        "esri/tasks/query",
            function (Query, Extent, FeatureLayer)
                console.log ("zoomRoomUse")
                query.objectIds = ids;
                roomUseLayer.selectFeatures (query, FeatureLayer.SELECTION_NEW, function (features)
                    var newExtent = new Extent ();
                    newExtent = features[0].geometry.getExtent ();
                    for (var k = 0; k < features.length; k++) {
                        newExtent = newExtent.union (features[k].geometry.getExtent ().expand (15));
                    labelRoom ();
I am having trouble updating it to 4.x
Mr_Kirkwood
I tried something like this:
    require ([
        "esri/rest/query",
                roomsUseLayer.definitionExpression = roomsUseLayer.objectIdField + " IN(" + ids.join(",") + ")";
                console.log (roomsUseLayer.definitionExpression)
                console.log(ids)
                view.whenLayerView (roomsUseLayer).then (function (layerView)
                    var query = roomsUseLayer.createQuery ();
                    query.objectIds = [ids];
                    roomsUseLayer.queryFeatures (query).then (function (results)
                        var geometry = features[0].geometry.extent.clone ();
                            geometry = geometry.union (features[k].geometry.extent.clone ());
                                roomsUseLayer.visible = true;
JoelBennett
Mr_Kirkwood
function zoomTreeTypes (ids)
    require ([
        "esri/rest/query",
                treeQueryLayer.definitionExpression = treeQueryLayer.objectIdField + " IN(" + ids.join (",") + ")";
                view.whenLayerView (treeQueryLayer).then (function (layerView)
                    var query = treeQueryLayer.createQuery ();
                    query.where = treeQueryLayer.definitionExpression;
                    treeQueryLayer.queryFeatures (query).then (function (results)
                        var geometry = features[0].geometry.extent.clone();
                        for (var k = 1; k < features.length; k++) {
                            treeQueryLayer.visible = true;
                            editTreeLayer.visible = false;
//                            graphics = results.features;
                        }).catch (function (error)
                            if (error.name != "view:goto-interrupted") {
                                console.error (error);
                            } else {
                                console.log ("Drawing");
I am trying to zoom to a group of queried points but the above code is getting an error.
Uncaught (in promise) TypeError: Cannot read properties of null (reading 'clone')
at this point in the code
Is there somethung different with zooming to points?
JoelBennett
As seen in the documentation, point objects don't have an extent (the value of their extent property is null).  You might want to built a single MultiPoint object from the points returned by your query and zoom to it instead.
