I'm thinking that 'dirty = dirty' means the same thing as '1=1' Neither worked.I made a sample that isn't using any secure data, which has eliminated that as the culprit, it still doesn't work for me. As far as seeing whether or not the query is OK on the click, I think the errors I'm seeing in the console are telling me that 'no' the query isn't executing properly, either with "", " ", or some other expression that resolves as true, like 1=1.
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">
<title>Feature Layer Filter Expression Example</title>
<link rel="stylesheet" type="text/css" href="https://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/dojo/dijit/themes/claro/claro.css">
<link rel="stylesheet" type="text/css" href="https://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/esri/css/esri.css" />
<link rel="stylesheet" type="text/css" href="https://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/esri/dijit/css/Popup.css">
<link rel="stylesheet" type="text/css" href="css/style.css">
<script type="text/javascript">
var dojoConfig = {
parseOnLoad: true
</script>
<script type="text/javascript" src="https://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.2"></script>
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("esri.map");
dojo.require("esri.dijit.Popup");
dojo.require("esri.layers.FeatureLayer");
dojo.require("dijit.form.Select");
dojo.require("esri.IdentityManager");
var map;
var startExtent;
var buildingLayer;
var buildingInfoTemplate;
var infoTemplateContent;
var pathName = "https://ogitest.oa.mo.gov";
var buildingAgencyList = [];
function init(){
esri.config.defaults.io.proxyUrl = pathName + "/proxy/proxy.ashx";
var highlightFillSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 255, 0]), 3), new dojo.Color([255, 255, 0, 0.05]));
var highlightMarkerSymbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE, 22, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 255, 0]), 2), new dojo.Color([255, 255, 0, 0.5]));
var popup = new esri.dijit.Popup({
fillSymbol: highlightFillSymbol,
lineSymbol: false,
markerSymbol: highlightMarkerSymbol
}, dojo.create("div"));
var spatialReference = new esri.SpatialReference({
wkid: 102100
startExtent = new esri.geometry.Extent(-10583000, 4287025, -9979000, 4980462, spatialReference);
map = new esri.Map("mapDiv", {
extent: startExtent,
fitExtent: true,
infoWindow: popup,
basemap: "gray"
map.infoWindow.resize(275, 600);
var countyLayer = new esri.layers.ArcGISDynamicMapServiceLayer(pathName + "/ArcGIS/rest/services/BaseMap/county_simple/MapServer", {
map.addLayer(countyLayer);
buildingInfoTemplateContent = "<b>${Facility}</b><br>" +
"Address: ${Address}<br>" +
"City: ${City}<br>" +
"Type: ${Type}<br>" +
"Years: ${Years}" ;
buildingInfoTemplate = new esri.InfoTemplate();
buildingInfoTemplate.setTitle("${Facility}");
buildingInfoTemplate.setContent(buildingInfoTemplateContent);
buildingLayer = new esri.layers.FeatureLayer(pathName + "/ArcGIS/rest/services/BaseMap/Education/MapServer/2", {
mode: esri.layers.FeatureLayer.MODE_ONDEMAND,
outFields: ["*"],
infoTemplate: buildingInfoTemplate
var buildingSymbol = new esri.symbol.PictureMarkerSymbol('images/orangeDiamond.png', 24, 24);
var buildingRenderer = new esri.renderer.SimpleRenderer(buildingSymbol);
buildingLayer.setRenderer(buildingRenderer);
map.addLayer(buildingLayer);
populateBuildingDropDown(buildingLayer);
function pointToExtent(map, point, toleranceInPixel) {
var pixelWidth = map.extent.getWidth() / map.width;
var toleraceInMapCoords = toleranceInPixel * pixelWidth;
return new esri.geometry.Extent( point.x - toleraceInMapCoords,
point.y - toleraceInMapCoords,
point.x + toleraceInMapCoords,
point.y + toleraceInMapCoords,
map.spatialReference );
function populateBuildingDropDown(buildingLayer){
buildingAgencyList.length = 0;
var queryTask = new esri.tasks.QueryTask(buildingLayer.url);
var query = new esri.tasks.Query();
query.outFields = ["*"];
query.where = "1=1";
query.returnGeometry = false;
//populates the pick list searching state facilities by agency
dojo.connect(queryTask, "onComplete", function (featureSet){
var select = dijit.byId("facilitySelect");
dojo.forEach(featureSet.features, function (feature){
var value= feature.attributes.Type;
buildingAgencyList.push(value);
buildingAgencyList.sort();
var sortedList = sortAndRemoveDuplicates(buildingAgencyList);
for (var i = 0; i < sortedList.length; i++) {
var bAgencyName = sortedList;
select.addOption({
label: bAgencyName,
value: bAgencyName
queryTask.execute(query);
function sortAndRemoveDuplicates(arr) {
var copy = arr.slice(0);
arr.length = 0;
for (var i = 0, len = copy.length; i < len; ++i) {
if (i === 0 || copy != copy[i - 1]) {
arr.push(copy);
return arr;
function filterFacilityByType() {
var e = dijit.byId("facilitySelect");
var code = e.value;
map.graphics.clear();
map.infoWindow.hide();
var filterExpression = "Type = '" + code + "'";
buildingLayer.setDefinitionExpression(filterExpression);
buildingLayer.setVisibility(true);
function toggleLayer (layerId) {
var layer = map.getLayer(layerId);
if (layer.visible){
layer.setVisibility(false);
}else{
layer.setVisibility(true);
function clearBuildingLayer () {
var exp = "";
var exp = "1=1";
var dirty = (new Date()).getTime();
buildingLayer.setDefinitionExpression(dirty + "=" + dirty);
//buildingLayer.setDefinitionExpression(exp);
buildingLayer.refresh();
select.reset();
dojo.addOnLoad(init);
</script>
</head>
<body class="claro">
<div dojotype="dijit.layout.BorderContainer" design="headline" gutters="false"
style="width: 100%; height: 100%; margin: 0;">
<div id="mainHeader" dojotype="dijit.layout.ContentPane" region="top" >
</div>
<div id="mapDiv" dojotype="dijit.layout.ContentPane" region="center" style="overflow:hidden;"splitter="true">
</div>
<div id="leftPane" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'left'"splitter="true" >
<button dojoType="dijit.form.Button" id="btnBuilding" class="togglebutton" iconClass="buildingIcon" onClick="toggleLayer('buildingLayer');" title="Turn State Facilities On/Off">
Facility
</button>
</br>
Filter facilities by type:
<select data-dojo-type="dijit.form.Select" id="facilitySelect" onchange="filterFacilityByType()" title="Display homes by level of care">
<option>Select type</option>
</select>
<button id="btnClear" dojotype="dijit.form.Button" onClick="clearBuildingLayer();" title="Clear Filter by Agency">Clear Results</button>
</div>
</div>
</body>
</html>
