Feature Layer zIndex
3357
05-31-2020 04:29 PM
AndrewMurdoch1
Good Day
I'm trying to figure out how change the elevation / zIndex of layer at creation, assuming I have N layers, and I want 'Base' to be on the bottom, how do I go about that?  This is my layer creation code:
let offset = '';
  if (!data[0].attributes.geoLayerName.toUpperCase().includes('BASE')) {
    offset = 'Geometry($feature).z + 10000';
  } else {
    offset = 'Geometry($feature).z + 10';
return {
  source: data,
  renderer: this.buildRenderSettings(colour, geometryType === 'point'),
  fields: this._fields,
  objectIdField: 'ObjectID',
  geometryType: geometryType,
  elevationInfo: {
    mode: 'absolute-height',
    featureExpressionInfo: {
      expression: offset
    unit: 'meters'
  spatialReference: {
    wkid: 4326
I'm utilizing a 2D map.
Thanks
Tags (1)
JohnGrayson
Esri Alum
From the Help doc:(FeatureLayer | ArcGIS API for JavaScript 4.15"This property may only be used in a SceneView".  Try controlling the layer order based on the order in the Map.layers collection.  If you need to reorder the layers after they've been added you can use the 'reorder()' method of the Map (Map | ArcGIS API for JavaScript 4.15)
AndrewMurdoch1
Thanks for the reply, it seems they made a large oversight.  I ended up reordering the map data before I convert it to Feature Layers which solves the problem.
