Feature Layer: Update Map with User Entered Definition Query
873
03-30-2013 07:18 PM
ChanLee3
I am working with a feature layer and I understand how the featureLayer.setDefinitionExpression() can be used to filter and display the contents that match the definition query.  What I want to do is take the user input and set that as the definition query and update the map after the user presses a submit button.
Here's what I have so far.
<script>
      dojo.require("esri.map");
      dojo.require("esri.layers.FeatureLayer");
      var map, featureLayer;
      function init() {
        map = new esri.Map("mapDiv", {
          basemap: "streets",
          center: [-97.395, 37.537],
          zoom: 7
        dojo.connect(map, "onLoad", initOperationalLayer);
      function initOperationalLayer(map) {
        var infoTemplate = new esri.InfoTemplate("${state_name}", "Population (2000) ${pop2000}");
        var prodGas = "PROD_GAS='Yes' AND PROD_OIL='No'";
        featureLayer = new esri.layers.FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Petroleum/KSPetro/MapServer/1",{
          mode: esri.layers.FeatureLayer.MODE_ONDEMAND,
          outFields: ["*"],
          infoTemplate: infoTemplate
        map.addLayer(featureLayer);
        map.infoWindow.resize(155,75);
        featureLayer.setDefinitionExpression(prodGas);
      dojo.ready(init);
    </script>
I created the variable prodGas to set my definition query.  I thought if I wrote a function to update the prodGas variable that the map will update with the new definition query but that doesn't seem to be the case.  For now I just set the prodGas variable as "PROD_GAS='Yes' AND PROD_OIL='No'" because I couldn't get the definition query and map to update correctly.  Can somebody help me work through this problem?
