Feature Layer not populating dgrid
5152
13
09-30-2013 06:42 AM
GeoffSchwitzgebel
I have properly configured the dgrid sample to load all of the map features that are loaded in the map.  I am now trying to incorporate this into my main application and I cannot figure out why it will not load the dgrid.  I have copied everything over so I'm not sure why it isn't working.  I am fairly new to the JS API and any assistance would be great.
Thank You,
Geoff
Here is my code:
           ready(function(){                 parser.parse();                  // create the dgrid                 window.grid = new (declare([Grid, Selection]))({                     columns: {                         "OBJECTID": "OBJECTID",                         "NAME": "Name",                         "OWNER": "Owner",                         "COUNTY": "County",                         "LATITUDE": "Latitude",                         "LONGITUDE": "Longitude"                         //"median": { "label": "Median Net Worth", "formatter": dojoNum.format },                         //"over1m": { "label": "Households Net Worth > $1M", "formatter": dojoNum.format }                     }                 }, "grid");                  // add a click listener on the ID column                 grid.on(".field-OBJECTID:click", selectState);                  var bounds = new Extent({                     "xmin": 1292510.8077427894,                     "ymin": 60762.840879261494,                     "xmax": 2759293.81036745,                     "ymax": 1233497.6866797954,                     "spatialReference": { "wkid": 3361 }                 });                  window.map = new Map("map", {                     extent: bounds,                     logo:false                 });                  var tiledMapServiceLayer = new esri.layers.ArcGISTiledMapServiceLayer("");                 map.addLayer(tiledMapServiceLayer                  var content = "<b>Name</b>: ${NAME}" + "<br /><b>Owner</b>: ${OWNER}" + "<br /><b>County</b>: ${COUNTY}"                   + "<br /><b>Acres</b>: ${ACRES}"                   + "<br /><b>Game Zone</b>: ${GAMEZONE}"                   + "<br /><b>DNR Region</b>: ${DNRREGION}"                   + "<br /><b>Latitude</b>: ${LATITUDE}"                   + "<br /><b>Longitude</b>: ${LONGITUDE}";                  var infoTemplate = new InfoTemplate("Dove Field", content);                  window.statesUrl = "";                 window.outFields = ["OBJECTID", "NAME", "OWNER", "COUNTY", "LATITUDE", "LONGITUDE"];//NEED TO ADD IN URL AFTER ADDING FIELD                  var fl = new FeatureLayer(window.statesUrl, {                     id:"states",                     mode: esri.layers.FeatureLayer.MODE_ONDEMAND,                     outFields: ["OBJECTID", "NAME", "OWNER", "COUNTY", "LATITUDE", "LONGITUDE"],//NEED TO ADD IN URL AFTER ADDING FIELD                     infoTemplate: infoTemplate,                 });                  fl.on("load", function () {                     fl.maxScale = 0; // show the states layer at all scales                     fl.setSelectionSymbol(new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_SQUARE, 20).setColor('#700000'));                 });                 // fl.on("click", selectGrid);                 var scalebar = new Scalebar({                     map: map,                     scalebarUnit: "dual",                     attachTo:"bottom-center"                 });                  fl.on("mouse-over", function () {                     map.setMapCursor("pointer");                 });                 fl.on("mouse-out", function () {                     map.setMapCursor("default");                 });                  map.addLayers([fl]);                  map.on("load", function (evt) {                     domStyle.set(registry.byId("mainWindow").domNode, "visibility", "visible");                     populateGrid(Memory); // pass a reference to the MemoryStore constructor                 });                  map.on("layers-add-result", function (evt) {                     var layerInfo = arrayUtils.map(evt.layers, function (layer, index) {                         return { layer: layer.layer, title: layer.layer.name };                     });                     if (layerInfo.length >= 0) {                         var legendDijit = new Legend({                             map: map,                             layerInfos: layerInfo                         }, "legendDiv");                         legendDijit.startup();                     }                 });                  function populateGrid(Memory) {                     var qt = new QueryTask(window.statesUrl);                     var query = new Query();                     query.where = "1=1";                     query.returnGeometry = false;                     query.outFields = window.outFields;                     qt.execute(query, function (results) {                         var data = array.map(results.features, function (feature) {                             return {                                 "OBJECTID": feature.attributes[window.outFields[0]],                                 "NAME": feature.attributes[window.outFields[1]],                                 "OWNER": feature.attributes[window.outFields[2]],                                 "COUNTY": feature.attributes[window.outFields[3]],                                 "LATITUDE": feature.attributes[window.outFields[4]],                                 "LONGITUDE": feature.attributes[window.outFields[5]]                             }                         });                         window.grid.renderArray(data)                     });                 }                 // fires when a row in the dgrid is clicked                 function selectState(e) {                     // select the feature                     var fl = map.getLayer("states");                     var query = new Query();                     query.objectIds = [parseInt(e.target.textContent)];                     //query.objectIds = [parseInt(e.target.innerHTML)];                     fl.selectFeatures(query, FeatureLayer.SELECTION_NEW, function (result) {                         if (result.length) {                             // re-center the map to the selected feature                             //window.map.centerAt(result[0].geometry.getExtent().getCenter());                             window.map.centerAt(result[0].geometry);                         } else {                             console.log("Feature Layer query returned no features... ", result);                         }                     });                 }                  // fires when a feature on the map is clicked - ORIGINAL CODE                 function selectGrid(e) {                     var id = e.graphic.attributes.OBJECTID;                     // select the feature that was clicked                     var query = new Query();                     query.objectIds = [id];                     var states = map.getLayer("states");                     states.selectFeatures(query, FeatureLayer.SELECTION_NEW);                     // select the corresponding row in the grid                     // and make sure it is in view                     grid.clearSelection();                     grid.select(id);                     grid.row(id).element.scrollIntoView();                 }               });            });
[HTML] <body class="claro">
      <div id="mainWindow"
          data-dojo-type="dijit/layout/BorderContainer"
          data-dojo-props="design:'headline', gutters:false"
          style="width: 100%; height: 100%;">
      <div id="header" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'">
        <div id="title">Pier and Bank Locator</div>
        <div id="queries">
            <button id="pierBtn" class="buttons" type="button">Pier</button>
            <button id="bankBtn" class="buttons" type="button">Bank</button>
            <button id="handicapBtn" class="buttons" type="button">Handicap Access</button>
            <button id="restroomBtn" class="buttons" type="button">Restrooms</button>
        </div>
        <div id="search" class="search">
            <input id="queryNameTxt"type="text" placeholder="Enter Name Here" >
            <button id="queryNameBtn" class="queryButton" type="button">Search</button>
        </div>
        <div id="filterDropDown" data-dojo-type="dijit/form/DropDownButton">
            <span>Choose Filter</span>
            <div data-dojo-type="dijit/TooltipDialog">
                <label for="name">Handicap Access</label><br>
                <label for="hobby">Restrooms</label>
                <label for="hobby">Picnic Shelter</label>
            </div>
        </div>
      </div>
      <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'">
          <div id="leftPane" data-dojo-type="dijit/layout/ContentPane"  data-dojo-props="region:'left'">
              <div id="legendPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="title:'Legend', selected:true">
                <div id="legendDiv"></div>
              </div>
            </div>
            <div id="logo" class="logo">
                <img src="images/DNRcolorRGB.jpg" width="40" height="50">
            </div>
      </div>
      <div id="footer" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom'">
        <div id="grid"></div>
      </div>
    </div>
  </body>[/HTML]
GeoffSchwitzgebel
Hey Jon,
Unfortunately we don't have any public facing services, they are all inside our network.  So I replaced the feature service and field information with the one that was used in the sample https://developers.arcgis.com/en/javascript/jssamples/fl_dgrid.html
Here is a link to the fiddle:
http://jsfiddle.net/gschwitz/8RvcR/5/
I also moved the parser down after the map and grid loaded and nothing changed.
Geoff
JonathanUihlein
http://jsfiddle.net/8RvcR/8/
Fixed. Made a number of small changes.
If you use a different dataset, you have to change the column definitions and the outFields for the new dataset.
Also, if your code fails silently, use try/catch blocks to identify the source of the error.
This is the best JS advice anyone ever gave me.
GeoffSchwitzgebel
Thanks for your assistance Jon.  So it looks like you moved the map, grid and memstore outside of the ready function and added the line window.grid.set("store", memStore); into the populateGrid function?
Geoff
JonathanUihlein
Geoff
I also changed a leftover reference from 'array' to 'arrayUtils,' made sure you were setting the correct idProperty for the store and removed a reference to a div with an id of 'container' that did not exist.
