exclude a map layer from the print task
5474
08-28-2015 12:55 PM
SebastianRoberts
Does anyone know how I can exclude a map layer from a print task?  I have an operational layer on my map, but don't want to include it in the resulting print.    I am passing a PrintParameters object to the print task.  I am assigning the Map object to the printparameters.map property.  I can remove a layer id from Map object, print the map, then add the layer id back to the Map object, but what I would really like to do is just remove the layer from the print.  I don't see how I can do this without cloning the entire Map object, removing the layer, and then assigning the cloned object to printparameters.map.  There must be a better way!
thejuskambi
You could simply set the visiblity of the layer to false, before passing the map to the print task and on print task complete you can turn the layer back on again. Thats what we do in our application.
MichaelVolz
Esteemed Contributor
Do you not want the layer to show up on the map or the legend in the print-out?
SebastianRoberts
I don't' want the layer to show on the map (and the legend in that case).
MichaelVolz
Isn't that confusing to the enduser to see a layer on the electronic map, but not the print-out?
SebastianRoberts
No, not in this case.
thejuskambi
