Example of a custom widget for the javascript viewer
1616
10-11-2012 07:51 AM
NakishaFouch
Am just curious if there are examples of adding a custom widget to the javascript viewer template?  I haven't really found anything around any of the esri sites and I am fairly new to javascript.  I have the code for the functionality of the new widget, I just need some insight on how to implement it via the custom widget and the organization of the custom widget code.
As always any info is greatly appreciated.
SteveCole
Honored Contributor
Wouldn't this be it?..
NakishaFouch
I see the pre-defined widgets on that page, but no custom widgets.  Best I have found so far is the custom infowindow example...so I am trying to work off that.
derekswingley1
The Writing a Class and Writing a Custom Widget from our conceptual help should provide some insight.
NakishaFouch
Thanks Derek!  That was helpful, I think I get the just of it.  I want to add a button/widget that lets me upload shapefiles.  I am working off the portal example.  Am curious if this can also be used via our server instead of arcgis.com?
