Event on change extent
1184
01-30-2023 04:16 AM
ADITYAKUMAR1
Hi ,
   I am trying to plot the cluster based on the zoom levels. But this is done while changing the map extent.
reactiveUtils.when(
() => this.map.mapView.stationary === true,
if (this.map.mapView.extent) {
this.myfunction();
The event is working on the change extent but on calling my function I am getting a different error.
Uncaught (in promise) l {name: 'AbortError', details: undefined, message: 'Aborted'}
Any idea why this error is appearing?
Thanks
Aditya kumar
Tags (1)
ReneRubalcava
Esri Frequent Contributor
Not able to replicate in the samples or a codepen, so I think it's going to depend on what this.myfunction() is doing. You might be trying to access properties that are still changing, or maybe something with the view. If you can provide a repro demo in codepen or github, could have a better idea.
