esriRequest calling a Asp.net Rest web service
987
12-07-2016 07:55 AM
JoseSanchez
Hello everyone,
I was able to call an asp.net vb.net Rest web service using this sample as template
https://developers.arcgis.com/javascript/3/jssamples/data_requestJson.html
and it works fine.
Now when I copy/paste the same code into the edit widget (Widget.js) code, it jumps from line:
var requestHandle = esriRequest
to line
this.editor.attributeInspector.refresh();
and it never executes this code: requestHandle.then(
I know that esriRequest is asynchronous, but I do not know how to change the code here to handle the return in the widget.
Here is the source code:
_worksAfterCreate: function (settings) {
       this.editor.templatePicker.on("selection-change", lang.hitch(this, function () {
                  var selected = this.editor.templatePicker.getSelected();
                  if (selected) {
                      var featureLayer = selected.featureLayer;
                      on.once(featureLayer, "before-apply-edits", lang.hitch(this, function (evt) {
                          if (evt.adds && evt.adds.length > 0) {
                              // Query WasdIndex Layer for Atlas and TTRRSS
                              this.query = new Query();
                              var countOfFeatures = 0;
                              var polygon = evt.adds[0].geometry;
                            var centroid = polygon.getCentroid();
                              this.query.geometry = polygon;
                              this.query.returnGeometry = true;
                              this.query.outFields = ['*'];
                              this.query.spatialRelationship = Query.SPATIAL_REL_INTERSECTS;
                              this.queryTask.execute(this.query, function (results) {
                                  // Populate ATLAS field
                                  if (results.features && results.features.length > 0) {
                                      dojo.forEach(results.features, function (feature) {
                                          countOfFeatures++;
                                          evt.adds[0].attributes.ATLAS = feature.attributes.ATLAS; }
                                  alert("Number of points in polygon " + countOfFeatures);
                                }, function (showErr) {
                                  console.log('error in query execution');
                              // Populate Comment for testing purposes
                              if (evt.adds[0].attributes.hasOwnProperty('COMMENTS')) {
                                  evt.adds[0].attributes.COMMENTS = 'TEST COMMENTS';
                              // Populate AASISID
                              if (evt.adds[0].attributes.hasOwnProperty('AASISID')) {
                                  esriConfig.defaults.io.proxyUrl = "/proxy/";
                                  var url = "http://localhost:59297/api/aasis";
                                  var requestHandle = esriRequest({
                                      "url": url,
                                      "handleAs": "json",
                                      "callbackParamName": "jsoncallback"
                                 requestHandle.then(                        <<<<=== THIS IS WHERE I HAVE THE PROBLEM
                                    function (response) {
                                      console.log("Success: ", response);
                                    function (error) {
                                        console.log("Error: ", error.message);
RobertScheitlin__GISP
Jose,
   So you are saying that you never get the console message that the web service was successful? Does your rest service not expect a input parameter?
