EsriGeometryPoint Clustering without WGS84 and web mercator
2846
11-02-2017 06:28 PM
kenlam
Hi, grateful if there is other clustering sample except for Samples | ArcGIS API for JavaScript 3.22
As I try to use FeatureReduction for feature layer, it prompts WGS84 message but I am under HK1980 environment.
Would there be any other alternative for EsriGeometryPoint or Feature Layer clustering?
Many thanks
RobertScheitlin__GISP
Ken,
   If you are not using WebMercator or WGS84 then you need to use a library like this one:
GitHub - Esri/cluster-layer-js: One example of how to cluster many point features
I have built an app using a  basemap with WKID 102629 and it works fine.
Ken,
   So you are using a custom base map that is in WKID 102140?
kenlam
I use a rare WKID 2326
Ken,
kenlam
Thanks. The problem make me smuggled for a week. I should have a try.
kenlam
OMG, this widget is very powerful
