esri/views/2d/engine/graphics/GFXObject
1807
12-26-2018 11:35 PM
ntpciland
Hi~
I have some problem with JS API 4.10
4.9 , GitHub - nickcam/FlareClusterLayer
require "esri/views/2d/engine/graphics/GFXObject", "esri/views/2d/engine/graphics/Projector"
But 4.10 without esri/views/2d/engine/*
RobertScheitlin__GISP
You need to request that the developer of that custom code update to 4.10
ntpciland
Thank you Robert Scheitlin
Maybe I will tell  the developer of flareclusterlayer update to 4.10 later
Actually I would like to know the difference between 4.9 and 4.10
Release notes for 4.10 | ArcGIS API for JavaScript 4.10 )
It doesn't tell me about "engine/graphics/GFXObject" remove or move to which Class
I don't believe that esri/views/2d/engine is a documented class that is suppose to be publicly used.
