esri.renderers.RasterStretchRenderer - Depreciated - Property: statistics
940
11-13-2024 09:09 AM
JaredPilbeam2
MVP Alum
[esri.renderers.RasterStretchRenderer]  DEPRECATED - Property: statistics
️ Replacement: customStatistics
 Version: 4.31
I updated my CDN from 4.27 to 4.31 and now I'm getting this warning. I think it's coming from the imagery2024 constructor. I don't have any statistics set in the code as my layers are in webmaps. I'm unsure how to fix it. Codepen
<link rel="stylesheet" href="https://js.arcgis.com/4.31/esri/themes/light/main.css" />
<script src="https://js.arcgis.com/4.31/"></script>
<script>
    require(["esri/Map",
        "esri/views/MapView",
        "esri/widgets/Search",
        "esri/widgets/Locate",
        "esri/widgets/LayerList",
        "esri/layers/ImageryLayer",
        "esri/widgets/Legend",
        "esri/widgets/Expand",
        "esri/widgets/Swipe",
        "esri/WebMap",
        "esri/layers/support/RasterFunction",
    ], (Map, MapView, Search, Locate, LayerList, ImageryLayer, Legend, Expand, Swipe, WebMap, RasterFunction) => {
        //webmap IDs
        const webmapids = [
            "e67a8eb6768641c19d4a7c5df394dbf4", //DTM
            "bfc5b0242adb42bfb0fc41e54497dfc8", //DSM
            "6ed3d2e495db4e859a73d2a32ce3d576", //HEDEM
            "d653b18bc941458491e06e657e10f393", //Intensity
            "a9ab25b1c7204764b2fabad6fc7a4635", //IR
            "e6bab92ebc524072a3305ec8f128e8f8", //Soil
            "2f9acebfb8db4e10bb6dddab8d3239c7", //ClosedDepressions
        * Create multiple WebMap instances
        const webmaps = webmapids.map((webmapid) => {
            return new WebMap({
                portalItem: {
                    // autocasts as new PortalItem()
        // add image services used in the swipe map
        const imagery2024 = new ImageryLayer({
            url: "https://gis.willcountyillinois.com/image/rest/services/Orthoimagery/Orthos_2024_3IN/ImageServer",
            rasterFunction: [],
            renderer: {
            type: "raster-stretch", //I added this while debugging: no difference
        webmaps[0].add(imagery2024);
         * Initialize the View with the first WebMap
        const view = new MapView({
            map: webmaps[0],
            container: "viewDiv",
            constraints: {
                maxScale: 500,
                minScale: 300000,
        console.log('construct the view')
UndralBatsukh
Hi there,
You needn't worry about these errors since your code does not touch statistics. This will be updated in the MapViewer in coming release.
UndralBatsukh
Hi there,
