Esri Map not loaded when its out of browser view port
1166
09-25-2024 03:35 PM
YangJin
Hi guys,
I’ve observed that the Esri Map only loads when it enters the browser’s viewport (I'm using Chrome), seems Esri has lazy loading mechanism for performance optimization. Is this behavior intentional, and if so, is there a way to force the map to load even when it's outside the viewport?
Yang
LionelGOUBET
what do you use ? a div with dipslay :'none' ?
YangJin
Im embed mapview into react.  I dont think I use
