ESRI map (control) on Internet Explorer 10 on Windows Surface / Windows 8 RT
1379
02-26-2013 05:46 AM
ThomasLaue
I have been trying to use some of the ESRI samples as well as my own application containing an ESRI map control with Internet Explorer 10 on Windows RT running on a Windows Surface device. However, I realized that it is quite hard or better nearly impossible to pan or zoom the map various touch gestures normally used to zoom pan are not interpreted correctly. Other maps like Google Maps or Bing Maps work correctly.
Does anyone has already used the ESRI map control successfully using Internet Explorer 10 on Windows RT? Does any possibility exist to influence the interpretation of touch gestures in combination with the ESRI map control?
Thank you very much for any information.
Best regards
Thomas
derekswingley1
IE10 is not currently supported. We are planning to have support for it at the next release (3.4).
ThomasLaue
Thank you very much for your reply. It is already known when the next release of the JavaScript API is going to be released?
