esri js 3.5 measurement ArcGISTiledMapServiceLayer problem
851
08-02-2013 01:20 AM
MustafaOgurlu
JS 3.5 api don't support Measurement Tool with projected ArcGISTiledMapServiceLayer.
Is anyone figured out this problem?
https://developers.arcgis.com/en/javascript/jssamples/widget_measureproject.html
This example only works with ArcGISDynamicMapServiceLayer
[HTML]
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
    on iOS devices-->
    <title>Measure Tool</title>
    <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/esri/css/esri.css">
    <style>
      html,body {
        height:100%;
        width:100%;
        margin:0;
      body {
        background-color:#FFF;
        overflow:hidden;
      #map {
        margin:5px;
        padding:0px;
        border:solid 4px #46472B;
      #measureWindow {
        position:absolute;
        right:35px;
        top:5px;
        z-index:998;
        width:245px;
        padding:20px;
        background:#46472B;
      .roundedCorners{
        -moz-border-radius:6px;
        -webkit-border-radius:6px;
        border-radius:6px;
      .innerDiv{
        background:#F1F1DC; padding:4px;
    </style>
    <script>        var dojoConfig = { parseOnLoad: true };</script>
    <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/"></script>
    <script>
        dojo.require("dijit.layout.BorderContainer");
        dojo.require("dijit.layout.ContentPane");
        dojo.require("esri.map");
        dojo.require("esri.dijit.Measurement");
        dojo.require("esri.dijit.Scalebar");
        var map;
        function init() {
            //This sample requires a proxy page to handle communications with the ArcGIS Server services. You will need to
            //replace the url below with the location of a proxy on your machine. See the 'Using the proxy page' help topic
            //for details on setting up a proxy page.
            esri.config.defaults.io.proxyUrl = "/proxy";
            esri.config.defaults.io.alwaysUseProxy = false;
            //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications
            esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://myserver/ArcGIS/rest/services/Geometry/GeometryServer");
            map = new esri.Map("map");
            dojo.connect(map, 'onLoad', function (map) {
                initToolbar(map);
            var layer = new esri.layers.ArcGISTiledMapServiceLayer("http://myserver/ArcGIS/rest/services/cachedlayer/MapServer");
            map.addLayer(layer);
        function initToolbar(mymap) {
            var measurement = new esri.dijit.Measurement({
                map: mymap
            }, dojo.byId('measurementDiv'));
            measurement.startup();
        dojo.ready(init);
    </script>
  </head>
  <body class="claro">
    <div id="mainWindow"  data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline',gutters:false"
    style="width:100%; height:100%;">
      <div id="map" class="roundedCorners" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'" style="position:relative;">
      <div class="roundedCorners" id="measureWindow" >
        <div class="innerDiv roundedCorners">
          <div id="measurementDiv"></div>
        </div>
      </div>
     </div>
    </div>
  </body>
</html>
[/HTML]
