ESRI Javascript API 3.3
9848
33
01-03-2013 09:56 AM
KevinMacLeod1
Hi all, It looks like the ESRI API for Javascript 3.3 is about to come out. The templates reference it. I was wondering if anyone knows roughly when it will come out or what is new? New Dojo version?
by Anonymous User
Not applicable
In the latest sample "Create a map", the syntax still is
dojo.require("esri.map");
should be
require(["esri/map"]);
JeffPace
my understand is at dojo 1.8 both are supported but the latter (newer format) is preferred, and at dojo 2.0 the latter format will be required.
So we can begin transitioning without breaking everything.
MarkHoover
Any other such transitions to get out in front of?
JeffPace
KenMorefield
should be
I'd agree that it would be nice if the ESRI samples all followed the require(["esri/map"]) way of coding.  For folks that are new to the javascript api and dojo - they might be learning the former way of coding their apps... then they'll have to start all over learning the upcoming new way...  just a thought.
Ken
AdrianMarsden
Honored Contributor
+ 1 on that - I've done all my coding in the "old" way with (for me) a majo app about to go to beta - So at the moment I have time to change - I just need pointing in the right direction - the info is there, but scattered around.  Having all the example moved to the new way of doing things would be great.
by Anonymous User
Not applicable
And many stuff CANNOT run well under IE7, such as Samples/map, http://help.arcgis.com/en/webapi/javascript/arcgis/jssamples/#sample/map_infowindow
KellyHutchins
Esri Notable Contributor
I ran a quick test of this sample in IE7 and it worked for me. Can you provide more details about what you mean by 'cannot run well'. Are you getting an error? Does the sample load?
by Anonymous User
Not applicable
Thanks Kelly for the quick response. The problem is when click second level navigation items in left side, the content in right side does not refresh. And the error is "Object doesn't support this action".
DawenXie
Kelly, can you please bring the search box back for "API Reference"? Or give a link for 3.2 if that's somewhere available for us. It's hard to check the reference now.
