Esri.dijit.print problem
1385
08-21-2013 05:45 AM
DainiusTamosiunas
I'm using Esri.dijit.Print to print a map with MAP_ONLY template. In the generated PDF only map graphics (Esri.graphics) are visible. Basemap and service layers (loaded on map in webapp) are not visible. Browsers not throwing any errors... Any suggestions?
DainiusTamosiunas
Fixed it. Looks like it was getting proxy generated layers urls which only works in map application server and printing is being executed on another server, so it was not able to reach those services that way. Got rid of proxy and it works as expected 🙂
JeffPace
are your basemap and service layers publicly accessible?
DainiusTamosiunas
Yes, they are publicly accessible.
DainiusTamosiunas
