esri.config.defaults.io.proxyUrl is not set.
4538
04-12-2013 10:12 AM
JasonCleaver
I am getting this error when I try to connect to a secured service. Here is the scenario.
ArcGIS for Server is behind our corporate firewall.  Access to this server from outside the firewall is over https.  IP traffic from the firewall/proxy to the server is http.
From my local developer machine, I added a dynamic layer -- http://internalservername/arcgis/rest/services/test/mapserver.  When I view the site using FireFox, the IdentityManager appears as expected.
Now I added a second dynamic layer -- https://externalservername.com/arcgis/rest/services/test/mapserver, pointing to the same exact service, on the same server.
When I refresh the browser, I am challenged twice, as expected.  Note:  I used the esri.ServerInfo() class because the URL for accessing the tokens from outside the firewall was http://externalservername.com/arcgis/tokens and it should really be https://externalservername.com/arcgis/tokens...
So, all is working until I remove the first layer, http://internalservername/arcgis/rest/services/test/mapserver
When I load the page, I am seeing two errors:
dojo.io.script.error Error: Token Requird
esri.config.defaults.io.proxyurl is not set
Jason
KellyHutchins
Esri Notable Contributor
Sounds like you  need to setup a proxy. Instructions on how to do so can be found here:
http://help.arcgis.com/en/webapi/javascript/arcgis/jshelp/ags_proxy.html
Once the proxy is working set the
esri.config.defaults.io.proxyurl to the url of the proxy.
