error using dojo's accordion and tabContainer with esri's js api
1042
07-13-2010 02:01 PM
ClintCabanero
Hello all,
When I use Dojo's Accordion and TabContainer dijits inside a Dijit Dialog, I get an error when using the ESRI ArcGIS Server JavaScript API version 1.6 and 2.0 beta.
When I run the same code with ESRI ArcGIS Server JavaScript API version 1.5 - I do not get these errors and everything works fine.
I use Dijits to build my custom UI for web apps.  ESRI please test that using Dojo dijits inside Dojo's floating dialogs work with the final release of 2.0.
Thanks!
KellyHutchins
Esri Notable Contributor
Clint,
Is this problem only occurring in a particular browser? Maybe IE? If so we added a sample that may help, take a look at the autofocus and refocus code.
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/map_dialog.htm...
