Error: Token Required on secured layers, but everything is working?
1171
04-21-2014 09:20 AM
JeffPace
Im getting a firebug error that is driving me nuts.  I get 17 errors, one for each secure layer in my map
...ost,w=r.crossOrigin):u=!!r);f=m.mixin({},f);f._ssl&&(f.url=f.url.replace(/^http:...
.cache["esri/request"]/</t/f.load@https://www.mymanatee.org/arcgis_js_api/library/3.9/arcgis/?v=3.9compact:631 .cache["dojo/_base/xhr"]/</b._ioSetArgs/<@https://www.mymanatee.org/arcgis_js_api/library/3.9/arcgis/?v=3.9compact:188 c@https://www.mymanatee.org/arcgis_js_api/library/3.9/arcgis/?v=3.9compact:75 d@https://www.mymanatee.org/arcgis_js_api/library/3.9/arcgis/?v=3.9compact:75 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback@https://www.mymanatee.org/arcgis_js_api/library/3.9/arcgis/?v=3.9compact:76 c@https://www.mymanatee.org/arcgis_js_api/library/3.9/arcgis/?v=3.9compact:75 d@https://www.mymanatee.org/arcgis_js_api/library/3.9/arcgis/?v=3.9compact:75 .cache["dojo/_base/Deferred"]/</b.Deferred/this.callback@https://www.mymanatee.org/arcgis_js_api/library/3.9/arcgis/?v=3.9compact:76 .cache["dojo/_base/xhr"]/</b.xhr/<@https://www.mymanatee.org/arcgis_js_api/library/3.9/arcgis/?v=3.9compact:192 .cache["dojo/Deferred"]/</k@https://www.mymanatee.org/arcgis_js_api/library/3.9/arcgis/?v=3.9compact:196 .cache["dojo/Deferred"]/</r@https://www.mymanatee.org/arcgis_js_api/library/3.9/arcgis/?v=3.9compact:196 .cache["dojo/Deferred"]/</f/this.resolve@https://www.mymanatee.org/arcgis_js_api/library/3.9/arcgis/?v=3.9compact:198 .cache["dojo/Deferred"]/</a@https://www.mymanatee.org/arcgis_js_api/library/3.9/arcgis/?v=3.9compact:197 .cache["dojo/Deferred"]/</k@https://www.mymanatee.org/arcgis_js_api/library/3.9/arcgis/?v=3.9compact:197 .cache["dojo/Deferred"]/</r@https://www.mymanatee.org/arcgis_js_api/library/3.9/arcgis/?v=3.9compact:196 .cache["dojo/Deferred"]/</f/this.resolve@https://www.mymanatee.org/arcgis_js_api/library/3.9/arcgis/?v=3.9compact:198 .cache["dojo/Deferred"]/</a@https://www.mymanatee.org/arcgis_js_api/library/3.9/arcgis/?v=3.9compact:197 .cache["dojo/Deferred"]/</k@https://www.mymanatee.org/arcgis_js_api/library/3.9/arcgis/?v=3.9compact:197 .cache["dojo/Deferred"]/</r@https://www.mymanatee.org/arcgis_js_api/library/3.9/arcgis/?v=3.9compact:196 .cache["dojo/Deferred"]/</f/this.resolve@https://www.mymanatee.org/arcgis_js_api/library/3.9/arcgis/?v=3.9compact:198 .cache["dojo/Deferred"]/</a@https://www.mymanatee.org/arcgis_js_api/library/3.9/arcgis/?v=3.9compact:197 .cache["dojo/Deferred"]/</k@https://www.mymanatee.org/arcgis_js_api/library/3.9/arcgis/?v=3.9compact:197 .cache["dojo/Deferred"]/</r@https://www.mymanatee.org/arcgis_js_api/library/3.9/arcgis/?v=3.9compact:196 .cache["dojo/Deferred"]/</f/this.resolve@https://www.mymanatee.org/arcgis_js_api/library/3.9/arcgis/?v=3.9compact:198 m@https://www.mymanatee.org/arcgis_js_api/library/3.9/arcgis/?v=3.9compact:158 f@https://www.mymanatee.org/arcgis_js_api/library/3.9/arcgis/?v=3.9compact:161
Doesnt tell me what request is being made.  The error occurs on layer creation, but before the "onlayeradd" event is fired.
I am using the identity manager, logging esri.id shows the credential object and all 17 resources listed prior to throwing the errors.  Any ideas? nothing is broken, but the firebug errors are really annoying
https://www.mymanatee.org/gisapps/mobile/index.html?type=utilitiesinfrastructure
u: util
p: util
JeffPace
no, but i no longer believe its an error.
I think the API treis to resolve a url.  When it errors, it logs it as an error, and then prompts with the identity manager.
So working as intended, but with misleading console.error logging.
JeffPace
Agreed.  It should be a warning, not an error
