Error: Script5022: No Region Setting for Map
1429
01-07-2013 10:33 AM
CraigMcDade
Getting the following error whenever I resize my app (open in IE) via the slider on the TOC.
SCRIPT5022: No region setting for map
utils.js, line 2 character 1078
Any clues on a fix or what I've done wrong? Its set as "center" in the HTML but I'm figuring thats not what the error is saying...
EDIT:
Turns out I had the center tag in the wrong div. I added it and it removed the error, however, the map doesn't resize...
EDIT 2:
Updated the resize statement to reference the correct Div.
