Error "position is deprecated" in javascript 3.13 api
7447
8
05-21-2015 11:08 AM
JurateMeister
For some reason just in a last few days I am getting this error :
The XMLHttpRequest progress event property 'position' is deprecated. Please use 'loaded' instead.
init.js:1485 dojo.io.script error Error_ssl: undefinedcode: 500details: Array[0]httpCode: 500log: undefinedmessage: nullstack: (...)get stack: function () { [native code] }set stack: function () { [native code] }__proto__: d
and this look:
The application used to work just fine and none changes has been  done. Is this error is on ESRI  side
AkshayHarshe
I am not sure why this would happen.
Is there any sample or application I can test with?
Akshay
Akshay Harshe
ReneRubalcava
Esri Frequent Contributor
The warning is actually coming from Chrome and pointing out where in the code it suggests a change be made.
You can see the warning in the console of Chrome DevTools on the samples pages.
ArcGIS API for JavaScript Sandbox
I think the warning is unrelated to the actual script error you are getting.
AkshayHarshe
Does this affect your application to load?
Akshay Harshe
JurateMeister
The application runs only on internal rest api, but here is the code:
http://codepen.io/jurate911/pen/EabJrY.html
http://codepen.io/jurate911/pen/EabJrY.css
http://codepen.io/jurate911/pen/EabJrY.js
It looks like application loads fine. all javascript functionality loads, map div comes up but there is no data within the map.
i appreciate all your help
TimWitt2
Jurate,
looking at your code it seems that you access your rest services through an internal network and not through a web server.
i.e.
    var basemap_tiled = new ArcGISTiledMapServiceLayer("http://pagis06:6080/arcgis/rest/services/Cache/BaseMapCache/MapServer", {
                title: "basemap_tiled"
Tim
JurateMeister
yes this app is available only on intranet for internal use only.
JurateMeister
it used to  work just fine for the last 5 month. I did not change anything and now can't figure out what change and where to start looking
AkshayHarshe
If the application loads and data doesn't show up and you know you haven't touched the code, may be check if all your services are working directly at the REST endpoint and your application has access to it. This can be a potential security issue.
Do you have any other error on the console in developer tools?
Akshay Harshe
