Error in Query Task with MapView
7562
20
07-12-2018 08:26 AM
Rocky_
I am trying to use query task with MapView.. able to run query and get results but cant get visual markers on map..
Am using Simple marker symbol for that markers.. Can anyone help me to get this markers after query task..
Thank you in advance.
Error:
Accessor#set Invalid property value, value needs to be one of 'esri.symbols.SimpleFillSymbol', 'esri.symbols.PictureFillSymbol', 'esri.symbols.PictureMarkerSymbol', 'esri.symbols.SimpleLineSymbol', 'esri.symbols.SimpleMarkerSymbol', 'esri.symbols.TextSymbol', 'esri.symbols.LabelSymbol3D', 'esri.symbols.LineSymbol3D', 'esri.symbols.MeshSymbol3D', 'esri.symbols.PointSymbol3D', 'esri.symbols.PolygonSymbol3D', 'esri.symbols.WebStyleSymbol', or a plain object that can autocast (having .type = 'simple-fill', 'picture-fill', 'picture-marker', 'simple-line', 'simple-marker', 'text', 'label-3d', 'line-3d', 'mesh-3d', 'point-3d', 'polygon-3d', 'web-style')
Rocky_
Thanks Michael. I'll try to make this changes. Thanks for useful information.
RobertScheitlin__GISP
??? Not sure I understand the question.
Rocky_
Ok..i'll try to explain it..
Right now am using only one service layer in which I can do some query tasks. So Is it possible to do query tasks in which contains multiple service layers.
Trying to perform query tasks on multiple layers on a single map view. If you still have question, let me know
Raj,
   If I understand you. Each query can only be executed against one layer at a time.
Rocky_
could you please give me an example snippet how to add 2 service layers to perform queries on them..
Raj,
   That is pretty basic. What does your code look like right now for querying one layer? All you need to do is duplicate that and point a new queryTask to the new layer url.
Rocky_
I am trying to do it but not working.. I found it bit tricky..
Raj,
   How do you plan to make this samples UI support querying more than one layer? Are all you layers going to be searched by the same attribute name and value based on the users interaction with the UI?
Rocky_
This one is for querying only one layer. i have all layers with different attributes. I share this with you to take a look and help me for adding more service layers .. I know, I need to add new query task for each layer on the basis of the attributes.. but right now having problem with adding multiple layers..when I try to add multiple layers cant able to run query tasks.
I am thinking to add multiple layers with manual selection to the user.. like below sample
https://developers.arcgis.com/javascript/latest/sample-code/layers-scenelayer-filter-query/index.htm...
Raj
Raj,
  Then something like this.
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>RouteTask - 4.8</title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    #paneDiv {
      position: absolute;
      top: 10px;
      left: 62px;
      padding: 0 12px 0 12px;
      background-color: rgba(0, 0, 0, 0.5);
      color: white;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.8/esri/css/main.css">
  <script src="https://js.arcgis.com/4.8/"></script>
  <script>
    require([
        "esri/Map",
        "esri/views/MapView",
        "esri/widgets/Home",
        "esri/widgets/Legend",
        "esri/widgets/Search",
        "esri/layers/GraphicsLayer",
        "esri/tasks/QueryTask",
        "esri/tasks/support/Query",
        "dojo/_base/array",
        "dojo/dom",
        "dojo/on",
        "dojo/domReady!"
      function(
        Map, MapView, Home, Legend, Search, GraphicsLayer, QueryTask, Query, arrayUtils, dom, on
        var RUrl = "https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/Prominent_Peaks_US/FeatureServer/0";
        var FUrl = "https://services.arcgis.com/V6ZHFr6zdgNZuVG0/ArcGIS/rest/services/2015_06_26_active_fires_USA_contig...";
        // Define the popup content for each result
        var popupTemplate = { // autocasts as new PopupTemplate()
          title: "{MTN_PEAK}, {STATE}",
          fieldInfos: [{
            fieldName: "ELEV_ft",
            label: "Elevation (feet)",
            format: {
              places: 0,
              digitSeperator: true
            fieldName: "ELEV_m",
            label: "Elevation (meters)",
            format: {
              places: 0,
            fieldName: "PROMINENCE_ft",
            label: "Prominence (feet)",
            format: {
              places: 0,
            fieldName: "PROMINENCE_m",
            label: "Prominence (meters)",
            format: {
              places: 0,
            fieldName: "ISOLATION_mi",
            label: "Isolation (miles)",
            format: {
              places: 0,
            fieldName: "ISOLATION_km",
            label: "Isolation (km)",
            format: {
              places: 0,
          content: "<b><a href='https://en.wikipedia.org/wiki/Topographic_prominence'>Prominence:</a>" +
            "</b> {PROMINENCE_ft} ft ({PROMINENCE_m} m)" +
            "<br><b>Prominence Rank:</b> {RANK}" +
            "<br><b>Elevation:</b> {ELEV_ft} ft ({ELEV_m} m)" +
            "<br><b><a href='https://en.wikipedia.org/wiki/Topographic_isolation'>Isolation:</a>" +
            "</b> {ISOLATION_mi} mi ({ISOLATION_km} km)"
        var popupTemplate2 = { // autocasts as new PopupTemplate()
          title: "{TRACK}",
          fieldInfos: [{
            fieldName: "TRACK",
            label: "Track"
            fieldName: "BRIGHT_T31",
            label: "Brightness",
            format: {
              places: 0,
            fieldName: "CONFIDENCE",
            label: "Confidence"
            fieldName: "SCAN",
            label: "Scan",
            format: {
              places: 0,
          content: "Brightness: {BRIGHT_T31}" +
            "<br><b>Confidence:</b> {CONFIDENCE}" +
            "<br><b>Scan: {SCAN}"
        var resultsLayer = new GraphicsLayer();
        var resultsLayer2 = new GraphicsLayer();
        var qTask = new QueryTask({
          url: RUrl
        var qTask2 = new QueryTask({
          url: FUrl
        var params = new Query({
          returnGeometry: true,
          outFields: ["*"]
        var map = new Map({
          basemap: "streets",
          layers: [resultsLayer, resultsLayer2]
        var view = new MapView({
          map: map,
          container: "viewDiv",
          zoom: 11,
          popup: {
            dockEnabled: true,
            dockOptions: {
              position: "top-right",
              breakpoint: false
        view.when(function() {
          view.ui.add("optionsDiv", "bottom-right");
          on(dom.byId("doBtn"), "click", doQuery);
        var attributeName = dom.byId("attSelect");
        var expressionSign = dom.byId("signSelect");
        var value = dom.byId("valSelect");
        var wlayer = dom.byId("lyrSelect");
        function doQuery() {
          // Clear the results from a previous query
          resultsLayer.removeAll();
          params.where = attributeName.value + expressionSign.value + value.value;
          if(wlayer.value === 'peaks'){
            qTask.execute(params)
              .then(getResults)
              .catch(promiseRejected);
          }else if(wlayer.value === 'fires'){
            params.where = 'BRIGHTNESS > 320';
            qTask2.execute(params)
              .then(getResults)
        function getResults(response) {
          var RResults = arrayUtils.map(response.features, function(
            feature) {
            feature.symbol = {
              type: "simple-marker",
              color: "red",
              outline: {
                color: "black"
              feature.popupTemplate = popupTemplate;
              feature.popupTemplate = popupTemplate2;
            return feature;
            resultsLayer.addMany(RResults);
            resultsLayer2.addMany(RResults);
          view.goTo(RResults).then(function() {
            view.popup.open({
              features: RResults,
              featureMenuOpen: true,
              updateLocationEnabled: true
          dom.byId("printResults").innerHTML = RResults.length +
            " results found!";
        function promiseRejected(error) {
          console.error("Promise rejected: ", error.message);
        var homeBtn = new Home({
          view: view
        }, "homeDiv");
        var legend = new Legend({
          view: view,
          layerInfos: [{
            url: RUrl
        legend.startup();
        view.ui.add(legend, "bottom-left");
        var searchWidget = new Search({
          view: view
        view.ui.add(searchWidget, {
  </script>
</head>
<body>
  <div id="viewDiv"></div>
  <div class="esri-widget" id="optionsDiv">
    <h2>Prominent Peaks in the U.S.</h2>
    <select class="esri-widget" id="lyrSelect">
      <option value="fires">US Fires</option>
      <option value="peaks" selected>US Peaks</option>
    </select>
    <select class="esri-widget" id="attSelect">
      <option value="ELEV_ft">Elevation</option>
      <option value="PROMINENCE_ft" selected>Prominence</option>
    </select>
    <select class="esri-widget" id="signSelect">
      <option value=">">is greater than</option>
      <option value="<">is less than</option>
      <option value="=">is equal to</option>
    </select>
    <select class="esri-widget" id="valSelect">
      <option value="1000">1,000 ft</option>
      <option value="5000">5,000 ft</option>
      <option value="10000">10,000 ft</option>
      <option value="15000">15,000 ft</option>
      <option value="20000">20,000 ft</option>
    </select>
    <br>
    <br>
    <button class="esri-widget" id="doBtn">Do Query</button>
    <br>
    <p><span id="printResults"></span></p>
  </div>
</body>
</html>
