Hi,I have been trying to locally host this webmap I created using AGOL (to modify it):http://dpwh.maps.arcgis.com/apps/MapTour/index.html?appid=7bd06d8330254b2688577d82f81bb92eIt uses the Map Tour template. I did step 1 of the readme file, and since I already had built the application inAGOL, skipped to step 5 and configured configOptions to use the appid, such as it now looks like thisconfigOptions = {
// Enter either a web map ID or a web application ID
// - Using a Map Tour application ID created through the interactive builder in ArcGIS.com allow to reuse
// the settings like the header configuration without having to edit any configuration here
// - Web map and application can be dynamically specified through url parameters (webmap and appid)
// if the authorizedOwners property is specified (see below)
// - If an application id is specified, the webmap configuration isn't used
webmap: "",
appid: "7bd06d8330254b2688577d82f81bb92e",
// Optional list of authorized application or web map owners
// Has to be specified when using appid or webmap url parameters (e.g. ["user1"], ["user1", "user2"])
authorizedOwners: [""],
// Select the application layout between "three-panel" and "integrated"
layout: "three-panel",
// The application header title, if no title is specified, the webmap's title is used
title: "",
// The application header subtitle, if not specified the ArcGIS.com web map's summary is used
subtitle: "",
// Optionally force a web map layer to be used as the tour points data source (can be overridden through URL)
// Otherwise the upper visible point layer is used (excluding map notes)
sourceLayerTitle: "",
// Use the first data record as an introduction instead of a point (can be overridden through URL)
firstRecordAsIntro: true,
// Optional zoom level to be applied for the story points following introduction (can be overridden through URL) (e.g: 0 to 16 for Gray Canvas, 0 to 19 for Street Map, -1 to disable)
zoomLevel: -1
Loading the local version however only produces a "Fatal error: Failed to get portal configuration" error. This is the case even if I only use the webmap id, or just load the page unmodified.Help please to make this work?Regards,Egan
