Error ArcGIS API for Javascript v3.1
8777
24
09-24-2012 12:17 AM
KristianLucido
i have a big problem with the new Api for Javascript. :confused: In my web app i have the version 2.7 and run correctly.
When i upgrade my webapp at version 3.1 i have this problem. I did the correct installation of the API.
Put the Api in a local webserver and change the configuration of "init.js" and "dojo.js" with correct parameters.
But this is the result:
[ATTACH=CONFIG]17910[/ATTACH]
Thanks in advance for the answer! 😉
KristianLucido
....and where is your application (web page) relative to the API?
C:\xampp\htdocs\<name of webapp>
DavideLimosani
Just to be sure...
those errors are very similar to mine when I call a page with api > 3.0 with the phisycal path "file:///C:/inetpub/wwwroot/test.html" instead of "localhost/test.html".
Are you calling your page in the proper way, right? In this case, are esri samples working on your webserver?
__Rich_
I hope we don't need to know about physical paths, only about the virtual paths provided by the web server.  (otherwise Davide is probably going to be correct! 😉 )
In the <script> element where you reference the API what have you got in the src attribute?
KristianLucido
Just to be sure...
Yes is very similar...but i call my web page with the correct url:
localhost/<name of web app>
or
192.168.13.56/<name of web app>
The esri samlpes run correctly. I use the sample in the installation guide and run!
What's the configuration for dojoConfig?
This is the code for include the API
<script type="text/javascript" src="http://192.168.13.56/arcgis_js_api/library/3.1/jsapi"></script>
__Rich_
Save the attached file (localapitest.htm) to the root of your site, in your case that appears to be C:\xampp\htdocs\
The click this link:
http://localhost/localapitest.htm
(it's just the sample file from the API zip)
What do you see?
(need to zip attachement to upload)
KristianLucido
What do you see?
I don't have this file in my zip Api.
But i try the example in the installation guide. this is the code:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <title>Simple Map</title>
    <link rel="stylesheet" type="text/css" href="http://localhost/arcgis_js_api/library/3.1/jsapi/js/dojo/dijit/themes/tundra/tundra.css">
    <script type="text/javascript" src="http://localhost/arcgis_js_api/library/3.1/jsapi/"></script>
    <script type="text/javascript">
      dojo.require("esri.map");
      function init() {
        var myMap = new esri.Map("mapDiv");
        //note that if you do not have public Internet access then you will need to point this url to your own locally accessible cached service.
        var myTiledMapServiceLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/NGS_Topo_US_2D/MapServer");
        myMap.addLayer(myTiledMapServiceLayer);
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="tundra">
    <div id="mapDiv" style="width:900px; height:600px; border:1px solid #000;"></div>
  </body>
</html>
and see this :
[ATTACH=CONFIG]17912[/ATTACH]
I have the same result with your file localapitest.htm
__Rich_
They are the same file, in the one I attached I had hard-coded the paths to the API based on your previous responses to make sure I understood the location of your API installation.
Can you post one of your files that doesn't work?
__Rich_
and in the configuration i put this url:
localhost/arcgis_js_api/library/3.1/jsapi/js/dojo/dojo
or
192.168.13.56/arcgis_js_api/library/3.1/jsapi/js/dojo/dojo
Where exactly did you put this?
KristianLucido
Thanks so much for the help 😉
Sorry but i can't post my file. Is a big web app and i work for important project and i can't post my file.
I follow the instruction for put the correct url. Subscribe [HOSTNAME_AND_PATH_TO_JSAPI] with the url. But the problem isn't the configuration in Api file because the example work good!
I don't understand :confused:
I'm going crazy :mad:
__Rich_
...and your app is definitely referencing the API the same way?
Just humour me, put this in your application page before the script element used to load the API:
<script type="text/javascript">     var dojoConfig = {         baseUrl:"http://localhost/arcgis_js_api/library/3.1/jsapi/js/dojo/dojo/"     }; </script>
