Equivalent to Dojo For V4.0
6674
05-27-2016 01:38 PM
MichaelHeirendt
What layout framework is included in the JavaScript API V4.0? in 3.16 Dojo was used, so there were many different layout options (border container, Accordion, content pane, etc). There are not many options I see other than using React? What would be the best way to go about formatting the HTML for my web map?
Tags (3)
SteveCole
Honored Contributor
According to the What's new document...
Version 4.0 of the ArcGIS API for JavaScript uses Dojo 1.10.4, dgrid version 1.0.0, and dstore version 1.1.1.
So I would assume that you can still use any Dojo objects present in 1.10.4. As for other options (React, NodeJS, etc), I would hope that there will be some presentations at the ESRI UC next month that would illustrate some of that. Rene Rubalcava​ is definitely the man when it comes to incorporating other libraries with the JS API so he might be able to offer some input.
Steve
SteveCole
Honored Contributor
Steve
MichaelHeirendt
That is helpful, I'll have to follow up after the users conference. Thanks!
ReneRubalcava
Esri Frequent Contributor
You can check out the frameworks session from DevSummit
Using Frameworks with the ArcGIS API for JavaScript | Esri Video
I also have numerous posts on my own blog using everything from React and Ember to Elm and CycleJS
odoenet - programming geo
MichaelHeirendt
Thanks for the links!
BjornSvensson
Esri Alum
Another option is Bootstrap. See for example the sample at https://developers.arcgis.com/javascript/latest/sample-code/frameworks-bootstrap/index.html
