Equivalent of "Select Features" and "Map Graphics" in Javascript 4
9378
16
05-03-2017 11:22 AM
SamuelAbati
I'm trying to migrate a webapp that was under development in the 3.7 API to use the 4.3 API
The base functionality of the app was that when the user would hold CTRL to click a point feature, it would make a SELECTION_ADD, selecting multiple features.
Also another functionality I can't find is changing the renderer/color of specific features, before I would go into the map graphics and change them directly (although I've found that wasn't the best way), now I'm not sure anymore
Everything gets even harder because I'm not working with FeatureLayer anymore, but instead a WebMap (which is a MapImageLayer)
In the end, my questions sum up to:
1) How to "select features" in a MapImageLayer/SubLayer, or any equivalent to getting the OBJECTID of a clicked feature.
2) How to change the renderer/color of specific features only, in this case would be the clicked features, but there is another case that is through a list of OBJECTIDs, (I believe this could be done by adding graphics on top of the features too, that would be no problem since my app is only for display purposes)
In 3.7 I used the layers events "click" and "selection-complete" to handle the logic, are these events no longer part of the flow of 4.X apps?
Any help as to where start or links to examples would be appreciated.
JayHill
Robert
I am getting lyrView.queryFeatures is not a function error.
app.view.whenLayerView(layer)
    .then(function(lyrView) {
app.view.on("click", function(event){
  console.log(event);
  var query = new Query();
  query.geometry = event.mapPoint;
  query.spatialRelationship = "intersects";
  lyrView.queryFeatures(query).then(function(results){
 console.log(results);
   var graphic = new Graphic({
     //gotta set a defined geometry for the symbol to draw
     geometry: results,
     symbol: new SimpleMarkerSymbol({
        //color: [0,255,255],
        style: "circle",
        //size: "18px",
        outline: {
             color: [255,255,0],
             width: 3
app.view.graphics.add(graphic);
console.log(graphic);
RobertScheitlin__GISP
Jay,
   What is your layer type?
JayHill
MapImageLayer
Jay,
   That is the reason. MapImageLayer view does not have a queryFeatures function.
JayHill
Ah ok. I thought this was a solution for using MapImageLayer
Thanks Robert
NathanielRindlaub
Jay, did you ever figure out a solution to this for MapImageLayer? I also would like to simulate a click on a mapImageLayer feature...
For that you just add a view click event handler and execute an identifytask or a query task for certain layers in th MapImageLayer using the mapPoint as the geometry
