Editor Widget - Moving a point not applying edit
1154
05-30-2012 11:36 AM
JamesS1
While editing with the Editor Widget, after moving a point, the edit is not applied. It is only applied if I change one of the field values after the move to the new location.
JamesS1
It looks like after a point is moved, if I click anywhere else in the map - the move gets saved.
Since there is no documentation on properties and events for the editorWidget, does anyone know if there is perhaps a "showApplyEdits button" that is hidden by default when viewing the infoWindow for a featurelayer edit? The "Delete" button is there and there is a property to hide it (although it is not documented).
SrikanthNarra
hi jsamek
        Where you are executing this one in Android or web browser.If it is the case of android it is bit difficult to place legend items on the map.
JamesS1
In a browser
