Editor-All Build up
6346
10
07-20-2015 09:49 AM
MichaelStranovsky
Using the selection tool on the toolbar of the editor widget to select multiple points.  When I click the attribute tool on the toolbar, I only get one feature in the AttributeInspector infowindow.   I do not get the navigation buttons on the AttributeInspector.
mapMain.on("layers-add-result", initEditing);
function initEditing (evt) {
  layers = arrayUtils.map(evt.layers, function(result) {
        return {featureLayer: result.layer};
  createEditor();
function createEditor() {
        if (myEditor) {
         return;
        var settings = {
        map: mapMain,
        enableUndoRedo: true,
            geometryService: new GeometryService("https://ags2.scgov.net/arcgis/rest/services/Utilities/Geometry/GeometryServer"),
            layerInfos: layers,
            toolbarVisible: true,
            toolbarOptions: {
              reshapeVisible: false
        var params = {settings: settings};
        myEditor = new esri.dijit.editing.Editor(params,domConstruct.create("div"));
        domConstruct.place(myEditor.domNode, "editorDiv");
        myEditor.startup();
DavidColey
MVP Frequent Contributor
Thanks Thejus, yes helpful for sure.  Yes, we've been sort of trial and error on this for some time. Anytime we set an info or popup window as part of the map or search constructer it completely hoses the attribute inspector and it's functionality.  You are likely correct in we will have create a specific AI.
