Editing large numbers via Feature Service
1128
07-04-2011 04:55 AM
PaulShaw1
I seem to be hitting an error when saving numbers of 11 digits or greater to a Float (or Integer) datatype when using the Javascript API attribute inspector. This seems to also occur in the ESRI Samples. For example, if I type a number like "12345678910" into the Length Km or WB Area Com ID fields in the ESRI Edit Rivers and Waterbodies sample
http://help.arcgis.com/en/webapi/javascript/arcgis/demos/ed/ed_simpletoolbar.html
I get an error, smaller numbers seem to save just fine. The range on a field like this is supposed to be ~16 digits. Has anybody else experienced this issue?
Many thanks,
Paul Shaw
SiqiLi
by Esri Contributor
I can type up to 16 digits for both the Length Km or WB Area Com ID fields. See the attached screen shot.
