Edit Vertices not working after migrating to ArcGIS Api 3.18 and doj 1.11.2
1234
09-30-2016 07:13 AM
YamunadeviRathinasamy
I recently migrated the JS api to 3.18 and dojo to 1.11.2.
And my map has multiple graphics layers for each type of geometry. and edit enabled on a polygon I can scale/move/rotate.
However I could not edit vertices. samething for polyline.
tool = edit.MOVE | edit.EDIT_VERTICES | edit.SCALE | edit.ROTATE;
options = { allowAddVertices: true, allowDeleteVertices: true, uniformScaling: true };
this.editToolbar.activate(tool, event.graphic, options);
getting the following error:
Unhandled exception at line 22, column 1 in http://localhost:63292/src/esri/PointerEvents.js?1475244454645
0x800a138f - JavaScript runtime error: Unable to set property 'numPoints' of undefined or null reference
