EDIT:is it possible to use the "editor widget" with geometry service and google maps?
1256
02-06-2012 01:17 AM
ChristianLutz
is it possible to use the "editor widget" with a gemoetry service when google maps is also included?
is there a link on how to do it?
AND: Will google maps be available in the future as well?
thanks!!!!!!
SwenWaschk
Have you seen:
http://help.arcgis.com/EN/webapi/javascript/gmaps/index.html?
I've looked at it but i don't see an editor widget.
You could use the regular javascipt api with bing maps instead of google maps.
ChristianLutz
Have you seen:
unfortunaltely bing maps has almost no data for the region (afghanistan).
is it possible to use the map object which uses google maps with the "editor widget" or does someone know a trick to have google maps in the background?
what about maps for the region afghanistan? does someone know a source?
thanks!!!!!!
