Drawing polygon is missing help line in JS API 4.10
2200
01-02-2019 02:23 AM
MarkusÅfelt
Noticed that helper line is missing from JS API 4.10. In 4.9 there was a helper line when creating polygon.
Now you need to click 2 points before seeing anything on the map.
I have attached examples for 4.9 & 4.10. JS API 4.9 draws white line when clicking first point of the polygon.
Is there a workaround to get it working on JS API 4.10?
Br,
Markus
RobertScheitlin__GISP
Markus,
   I know there were many changes made to drawing in 4.10. I believe that the way it is now in 4.10 is the intended way for Draw to work. Draw is suppose to allow the developer to customize and handle all aspects of the drawing. Here is how I handle it.
      // create a new graphic presenting the polyline that is being drawn on the view
      function createGraphic(event) {
        const vertices = event.vertices;
        view.graphics.removeAll();
        if(event.vertices.length === 2){
          var polyline = {
            type: "polyline", // autocasts as Polyline
            paths: event.vertices,
            spatialReference: view.spatialReference
          var drawGra = new Graphic({
            geometry: polyline,
            symbol: { // autocasts as SimpleLineSymbol
              type: "simple-line",
              color: "white",
              width: 1
          view.graphics.add(drawGra);
          return;
        // a graphic representing the polyline that is being drawn
        const graphic = new Graphic({
          geometry: {
            type: "polygon",
            rings: vertices,
          symbol: {
            type: "simple-fill", // autocasts as SimpleFillSymbol
            color: "purple",
            style: "solid",
            outline: { // autocasts as SimpleLineSymbol
              color: "white",
              width: 1
        view.graphics.add(graphic);
Markus,
          var polyline = {
            geometry: polyline,
              color: "white",
              width: 1
          return;
          geometry: {
            type: "polygon",
            rings: vertices,
          symbol: {
            color: "purple",
            style: "solid",
              color: "white",
              width: 1
MarkusÅfelt
Hi Robert,
Thanks for quick response, this solved my problem.
