draw window Polygon error.
1429
12-14-2016 06:47 AM
Ramon_Torkelson
I have a draw window using the dijit/form/Button with 3.18. All of these seem to work as expected except the Polygon. A significant part of the time I get the error: Unhandled exception at line 7, column 371 in http://js.arcgis.com/3.18/esri/toolbars/edit.js Unable to activate the tool ...
Tags (1)
TyroneBiggums
You might have to post your code.
