Draw widget in calcite
1419
04-12-2018 05:20 AM
YvesMoisan
Hi All,
I have tweaked the basic viewer template for a customer and I'm looking for ways to add a custom Draw widget (with only some drawing operations allowed, like add point, and my custom symbols).  I have my symbols ready as JSON representations in a separate file.  But my attempts at adding a Draw widget in the main toolbar have failed.
The template I'm using has this for css :
<link rel="stylesheet" href="https://js.arcgis.com/3.24/esri/themes/calcite/dijit/calcite.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.24/esri/css/esri.css">
<link rel="stylesheet" href="css/styles.css">
I'm willing to spend a bit of time adding the draw widget in the calcite theme, but I see there are many variations of the calcite theme.  Is the Draw widget implemented in any of those variations ? I would appreciate pointers as to how to go about this.  I don't have much time for this so if I could get access to development code bits I would appreciate.
TIA,
Yves
KellyHutchins
Esri Notable Contributor
HI Yves,
What type of issues are you running in to? The Basic Viewer app is built using the 3.x version of the JSAPI so I assume you are trying to integrate the Draw toolbar? It doesn't use the css from the calcite/widget theme so the draw tools should work just fine in an app that is using Calcite. Here's an example:
JS Bin - Collaborative JavaScript Debugging
YvesMoisan
Thanx Kelly.
