Draw / DrawAction event typing issue on 5.x
536
03-02-2026 12:50 AM
EirikH
When upgrading from 4.34.x to 5.0.5/5.0.6, typescript complains about the types for the on event listeners for DrawAction.
To recreate, just setup this example from the docs in a typescript project.
function enableCreatePolygon(draw, view) {
  let action = draw.create("polygon");
  // PolygonDrawAction.vertex-add
  // Fires when user clicks, or presses the "F" key.
  // Can also be triggered when the "R" key is pressed to redo.
  action.on("vertex-add", function (evt) { // <- ERROR:  Argument of type '"vertex-add"' is not assignable to parameter of type 'never'.ts
    createPolygonGraphic(evt.vertices);
  // PolygonDrawAction.vertex-remove
  // Fires when the "Z" key is pressed to undo the last added vertex
  action.on("vertex-remove", function (evt) {  // <- ERROR:  Argument of type '"vertex-remove"' is not assignable to parameter of type 'never'.ts
  // Add a graphic representing the completed polygon
  // when user double-clicks on the view or presses the "Enter" key
  action.on("draw-complete", function (evt) {  // <- ERROR: Argument of type '"vertex-add"' is not assignable to parameter of type 'never'.ts
function createPolygonGraphic(vertices){
  view.graphics.removeAll();
  let polygon = {
    type: "polygon", // autocasts as Polygon
    rings: vertices,
    spatialReference: view.spatialReference
  let graphic = new Graphic({
    geometry: polygon,
    symbol: {
      type: "simple-fill", // autocasts as SimpleFillSymbol
      color: "purple",
      style: "solid",
      outline: {  // autocasts as SimpleLineSymbol
        color: "white",
        width: 1
  view.graphics.add(graphic);
There is a post on something similar, but our lib is already ES2024.
https://community.esri.com/t5/arcgis-javascript-maps-sdk-questions/typescript-event-inference-no-lon...
Our version of Typescript is latest 5.9.3.
Other "on" events we have in the project (e.g. mapView.on) work as expected.
If you "cast" to a specific DrawAction, it picks the eventTypes up correctly:
const action = draw.create(mode, { mode: 'freehand' }) as SegmentDrawAction;
action.on('draw-complete', drawCompletedHandler); // all fine now
ReneRubalcava
Esri Frequent Contributor
You hit the nail on the head with the casting. This is how you can get the action typings you are looking for. We can look at this further and see if we can infer this in a future release, but that is the current solution.
EirikH
Thanks, hope you figure out a way 🤞
