Draw cursor offset issue
6389
14
05-14-2014 11:36 AM
AlexGole1
I am using the following: http://jsbin.com/mutis/1/edit  script and I get a cursor offset when I draw using a freehand poly or simple poly. I noticed that some people have had the same issue in the past. Can anyone tell me how to fix this?
Thank you,
Alex
AlexGole1
i just left everything right where it was.
<section id="fancy"  ...
<section id="search" ></section>
</section>
Do I remove the content pane then?
<section id="map" class="map" section data-dojo-type="dijit/layout/ContentPane" region="center" data-dojo-props="region:'center'">
JohnGravois
as i said before...
AlexGole1
as i said before...
Sorry I know it must make sense to you and it seems to be an easy fix but I am still a bit lost with the logic you are using. Can you share it with JSbin maybe?
JohnGravois
my apologies, but i just realized that i had commented out all of our drop shadow divs earlier to try and simplify your app a little bit.
http://jsfiddle.net/jagravois/Dy4r4/
ill have to leave it to you if you'd like to try and add them back in and sort out the rest on your own.
AlexGole1
Thank you very much John! I get it now. Very well done! Thank you for your help and patience!
Alex
