Draggable Marker
3421
03-17-2022 08:07 PM
Tarak-Kar
I need to have a draggable marker on the map something like how it is working in the example below -
https://developer.here.com/documentation/examples/maps-js/markers/draggable-marker
Thanks
ReneRubalcava
Esri Frequent Contributor
Here is a sample of how to do this on a hold event.
https://codepen.io/odoe/pen/bLEroK?editors=0010
  view.on("hold", ({ mapPoint }) => {
    view.hitTest(view.toScreen(mapPoint)).then((hitResult) => {
      if (!hitResult.results[0].graphic) return;
      console.log("hold event, now drag mouse to move graphic");
      pointGraphic.symbol = selectSymbol;
      const pausePan = view.on("drag", stop);
      const move = view.on("pointer-move", updateGraphic);
      const up = view.on("pointer-up", cleanUp);
      handlers.push(pausePan);
      handlers.push(move);
      handlers.push(up);
KrishnaReddyRanabothu
Hi @ReneRubalcava,
I am trying in indoor map on floors, if I do drag and drop on floor it is going to ground floor,  How can I place on floor.
Thanks!
Krishna
RussellMGreen
@ReneRubalcava how would you make the marker draggable without having to "long press" (hold) the marker? I'm looking for standard marker drag/drop behavior (hover over marker, get pointer, click and drag marker).
Thanks!
ReneRubalcava
You'd need to add some logic to handle when you click to start moving it and click to stop. Here's an updated demo.
https://codepen.io/odoe/pen/VwVrxBJ?editors=0010
    if (pause) {
      handlers.forEach((a) => a.remove());
      handlers.length = 0;
      pause = false;
      return;
