Drag and Drop Icon/Image
1609
09-24-2011 11:43 PM
zeeshanbhatti
HI
I am drawing and loading png images using "esri.symbol.PictureMarkerSymbol". How i can drag and drop. There is no example mentioned in http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm
i just found loading file CSV in search of drag and drop. but my requirment is simply to drag the image. Thanks
Regards,
Zeeshan
derekswingley1
What have you tried?
The sample you mentioned, File Access with Drag and Drop, does handle images. Check out the handleImage function in the source.
AnjithaSenarath
How do you drag and drop an point marker Icon (image). We would like to have a sample on achieving it in flex environment. If you know how to do that please reply
