Double-click event & infoWindow
4226
07-27-2016 11:50 AM
SteveCole
Honored Contributor
I'm having a little trouble with the double click event and infoWindows. My featureLayer has a popup associated with it which displays when features are single clicked. I want to implement a double click to toggle between starting/stopping vertex editing. When I double click a feature, I still get the popup window even though I think I have coded to prevent it:
        theLayer.on("dbl-click", function(evt) {
            map.infoWindow.hide();
            event.stop(evt);
             //Do Something...
I would imagine that the event.stop() method is only addressing the double click event and not the single click event so how do I stop the popup during a double click event?
KenBuja
MVP Esteemed Contributor
Have you tried pausing the map's click event when you are doing vertex editing? "dojo/on" has a pausable method where you can stop and start the event as needed.
KenBuja
SteveCole
Honored Contributor
Thanks, Ken. I haven't looked into that method before. It seemed a little confusing at first but I think I know how I might implement it. I'm using a "control key + click" event in order to bring up the attributeInspector so I'm thinking I could also just pause the click event listener at that time and then resume it when the attributeInspector is dismissed.
We'll see how that goes. Thanks for the tip!
Steve
SteveCole
Honored Contributor
I marked Ken's response as correct because, well, it is technically correct and likely a sound approach. I have decided to go a simpler route instead since I was going to need to pause/resume click events on multiple feature layers and that seemed like it was destined to be a headache.
The alternative was to add a button to my attribute inspector and serve as a toggle button. Click once to enable vertex editing and click a second time to save changes.
        editShapeButton.on('click',function(e) {
            if(app.editingEnabled) {
                app.editToolbar.deactivate();
                app.attInspector._currentFeature._layer.applyEdits(null,[app.attInspector._currentFeature],null);
                editShapeButton.set("label","Edit Shape");
                app.editingEnabled = false;
            } else {
                app.editToolbar.activate(Edit.EDIT_VERTICES, app.attInspector._currentFeature);
                editShapeButton.set("label","Save Edits");
                app.editingEnabled = true;
