dom.byId won't parse
3552
12
05-15-2014 10:47 AM
williamcarr
Greetings,
I assume that this is a parsing issue, but I can't be for the life of me figure how.
     var option= dom.byId("selectfield");    var optionValue = option.options[option.selectedIndex].value;    console.log(optionValue);                     if (optionValue == "ON"){map.centerAndZoom(pt, 12);}   else {}  }
This is the section that is causing me grief. When I remove parser.parse();  the function runs fine. The problem is all of my title panes and content panes get thrown totally out of whack. Without it I'm getting " option.selectedIndex is undefined".
I'm using this a dropdown to toggle the center and zoom of a watch ID.
Anyone know what might be causing this?
JeffPace
var option= registry.byId("selectfield");
   var optionValue = option.value;
http://jsfiddle.net/v2shP/7/
JonathanUihlein
Make sure to include the dojo modules you are using in your require block (BorderContainer, ContentPane, TitlePane, Menu, MenuItem, DropDownSelect etc).
If this doesn't work, you can always create a jsfiddle that showcases your issue; I would be glad to take a look.
williamcarr
Thanks for taking a look. This fiddle doesn't include the majority of the code just the geolocation. The code works as expected but when combine with the parser.parse(); I get the error.http://jsfiddle.net/thebillcarr/v2shP/1/
JeffPace
I was able to add parser.parse() to yours
http://jsfiddle.net/v2shP/5/
you must also use ready.
but i am not sure what to do after that
williamcarr
That fixed the content panes, but now the dom.byId  isn't running its if statement. I tried it on a tablet and it will run the zoomToLocation function. The showLocation function is also running, but the IF statement is not going through when I add the code to the rest of my application.
   addGraphic(pt);
        if (option.value == "ON"){map.centerAndZoom(pt, 12);}
  else {}
Am I going about this wrong? Is there a different way to toggle map.centerAndZoom?
JeffPace
option is your dom element, shouldnt you be using optionValue in your if?
JeffPace
or, since selectfield is a dijit.form.select,
you could do
registry.byId('selectfield').value to get the dijit value (instead of the dom element)
williamcarr
Correction, I did have optionValue in my IF when I got it to work on it's own(not sure why I changed it).
I tried the registrybyId and it threw the same console error "option.selectedIndex is undefined".
  else {}
I'm not sure why this conflicted with the parser, but I'm wondering now if it doesn't have something to do with
<select data-dojo-type="dijit/form/Select" class="field" name="selectfield" id="selectfield">
    <option value="ON">TRACKING ON</option>
  <option value="OFF">TRACKING OFF</option>
  </select>
I'm at a loss. Can you think of a work around?
JeffPace
MatthewLofgren
It doesn't look like dom is defined in the fiddle?
require([
        "esri/map", "esri/geometry/Point",
        "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol",
        "esri/graphic", "esri/Color", "dojo/domReady!"
      ], function(
        Map, Point,
        SimpleMarkerSymbol, SimpleLineSymbol,
        Graphic, Color
try
require([
        "dojo/dom", "esri/map", "esri/geometry/Point",
      ], function(
        dom, Map, Point,
        Graphic, Color
