Dojox Charting
3087
07-21-2014 06:41 PM
GraySanders
I was wondering if anyone has used dojox charting in their web map. I made a test map using the popup and mediainfos type:"linechart", however I need more control over the chart. I need to label the x-axis and invert y-axis in the chart.
So after a lot of searching on google I believe that I need to use dojox charts.
Something like this - http://dojotoolkit.org/reference-guide/1.10/dojox/charting.html
require(["dojox/charting/Chart", "dojox/charting/axis2d/Default", "dojox/charting/plot2d/Lines", "dojo/ready"],
  function(Chart, Default, Lines, ready){
  ready(function(){
    var chart1 = new Chart("simplechart");
    chart1.addPlot("default", {type: Lines});
    chart1.addAxis("x");
    chart1.addAxis("y", {vertical: true});
    chart1.addSeries("Series 1", [1, 2, 2, 3, 4, 5, 5, 7]);
    chart1.render();
I would like to place a chart like this example in a popup - http://dojotoolkit.org/documentation/tutorials/1.8/charting/demo/monthly-sales.php
I would be very grateful if someone could show an example or give some guidance.
Thank you
Gray
link to test map - HPWD Observation Map
This is my current code
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Simple Map</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
    <style>
      html, body, #map {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
      body {
        background-color: #FFF;
        overflow: hidden;
        font-family: "Trebuchet MS";
    </style>
    <script src="http://js.arcgis.com/3.10/"></script>
    <script>
      var map;
      require(["esri/map", "esri/layers/ArcGISTiledMapServiceLayer", "esri/layers/FeatureLayer", "esri/dijit/Popup", "esri/dijit/PopupTemplate", "dojo/domReady!"],
      function(Map, Tiled, FeatureLayer, Popup, PopupTemplate) {
        map = new Map("map", {
          basemap: "topo",
          center: [-102.040536, 34.188206], // longitude, latitude
          zoom: 13
        var tiled = new Tiled("http://gis.hpwd.com/arcgisweb/rest/services/obswells2014v2/MapServer");
        map.addLayer(tiled);
          var template = new PopupTemplate({
          title: "HPWD Water Levels",
          description: "Observation Well Number: {StateWellN}",
          fieldInfos: [{ //define field infos so we can specify an alias
            fieldName: "DTW_2004",
            label: "2004"
            fieldName: "DTW_2005",
            label: "2005"
            fieldName: "DTW_2006",
            label: "2006"
            fieldName: "DTW_2007",
            label: "2007"
            fieldName: "DTW_2008",
            label: "2009"
            fieldName: "DTW_2009",
            label: "2009"
            fieldName: "DTW_2010",
            label: "2010"
            fieldName: "DTW_2011",
            label: "2011"
            fieldName: "DTW_2012",
            label: "2012"
            fieldName: "DTW_2013",
            label: "2013"
            fieldName: "DTW_2014",
            label: "2014"
          mediaInfos:[{ //define the bar chart
            caption: "",
            type:"linechart",
            value:{
              fields:["DTW_2004","DTW_2005","DTW_2006","DTW_2007","DTW_2008","DTW_2009","DTW_2010","DTW_2011","DTW_2012","DTW_2013","DTW_2014"]
        var featureLayer = new FeatureLayer("http://gis.hpwd.com/arcgisweb/rest/services/obswells2014v2/MapServer/1",{
          mode: FeatureLayer.MODE_ONDEMAND,
          outFields: ["*"],
          infoTemplate: template
        map.addLayer(featureLayer);
    </script>
  </head>
  <body>
    <div id="map"></div>
  </body>
</html>
