Dojox chart in panel
7874
14
04-05-2017 01:50 PM
MichelleJean
I created a dojox chart using the Info window with chart tutorial.
I am using info window and the Measurement widget but this combination seems not to be working because every time you click to create a measurement the info window appears and covers your region of interest.
One solution would be to dock the popups but that is only available in JavaScript 4.x which does not support the Measurement widget.
So I guess I need to put the popups in a panel.
I used the sample code from the Popup content in side panel tutorial to integrate the popups in my Popup Panel but I am missing something in the code because it's not working.
Any support with the code would be very helpful.
My map in the ESRI Calcite Maps theme is available on JS Bin.
// From tutorial "Popup content in side panel"
 function(error){
 console.log("Map creation failed: ", dojo.toJson(error));
  </script>‍‍‍‍‍
Thank you,
Michelle
MichelleJean
Hi Robert,
I added the code after measurement and it doesn't seem to have an effect:
var measurement = new Measurement({
  map: window.map,
}, dojo.byId('measurementDiv'));
measurement.startup();
aspect.after(measurement, 'setTool', function() {
  if (measurement.activeTool) {
    map.setInfoWindowOnClick(false);
  } else {
    map.setInfoWindowOnClick(true);
Thank you,
Michelle
RobertScheitlin__GISP
Michelle,
   Did you add the require for aspect?
MichelleJean
Sure. I attached the files.
Michelle,
   Because you where showing the chart based on a layer click event handler and not just using the layers popup you need to use on.pausable for the layers click event:
require([
    "esri/layers/FeatureLayer",
    "esri/dijit/Measurement",
    "esri/InfoTemplate",
    "dijit/layout/TabContainer",
    "dijit/layout/ContentPane",
    "dojo/dom-construct",
    "dojo/dom-class",
    "esri/arcgis/utils",
    "dojo/query",
    "dojo/on",
    "dijit/registry",
    "dojo/dom",
    "calcite-maps/calcitemaps-v0.3",
    "bootstrap/Collapse",
    "bootstrap/Dropdown",
    "bootstrap/Tab",
    "dojo/Deferred",
    "dojo/domReady!"
  function(FeatureLayer, Measurement, InfoTemplate, TabContainer, ContentPane, domConstruct, domClass, arcgisUtils, query, on, registry, dom, CalciteMaps, Deferred) {
    esri.config.defaults.io.proxyUrl = "http://gislap183/proxy/proxy.ashx";
    esri.config.defaults.io.alwaysUseProxy = false;
    esri.config.defaults.geometryService = new esri.tasks.GeometryService("https://utility.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
    arcgisUtils.createMap("25bc5a52ccd746c89daefa179cae0036", "mapViewDiv", {
      usePopupManager: true
    }).then(function(response) {
        window.map = response.map;
        window.map.infoWindow.set("popupWindow", false);
        initializeSidebar(window.map);
        var statesLayer = new FeatureLayer("http://services7.arcgis.com/6FZUQ16zBFwjeNsQ/arcgis/rest/services/Feat_Lay_WFL/FeatureServer/0", {
          outFields: ["*"]
        var stateClickHandler = on.pausable(statesLayer, "click", generatePopup);
        window.map.addLayer(statesLayer);
        function generatePopup(evt) {
          require(["app/CreateChart"], function(CreateChart) {
            if(!CreateChart) {
              console.log("Module not loaded");
              return;
            var chart = new CreateChart({
              graphic: evt.graphic
            var chartContent = chart.createPieChart();
            window.map.infoWindow.setFeatures([evt.graphic]);
            if(!domClass.contains(query("#panelPopup")[0], "in")) {
              query("#panelPopup").collapse("toggle");
            registry.byId("chartPanel").set("content", chartContent);
          map: window.map,
        // ------------ disable chart when using Measurement Widget -----------------------------------
          if(measurement.activeTool) {
            stateClickHandler.pause();
          } else {
            stateClickHandler.resume();
      function(error) {
    function initializeSidebar(map) {
      var lp = new ContentPane({
        style: "height:235"
      }, dom.byId("chartPanel"));
      lp.startup();
MichelleJean
Thank you Robert
