dojo Data grid not display data
2782
04-15-2015 02:26 AM
NadirHussain
HTML CODE
<table data-dojo-type="dojox.grid.DataGrid"  id="grid" selectionMode="none" style="height:96%;width:96%;margin:5px; border:4px solid black;">
                                         <thead>
                                            <tr>
                                                <th field="ObjectID"  width="50px">
                                                    <img alt="+" src="Images/nav_zoomin1.png"/>
                                                </th>
                                                <th field="SIREN_NO" width="100px">Siren Number</th>
                                                <th field="Reg_E" width="200px">Region English</th>
                                            </tr>
                                        </thead>
  </table>
JAVA SCRIPT CODE
function executeQueryTask(strRegionName, strCityName, intCondition) {
                   var items = []; //all items to be stored in data store
                   var featureAttributes;
                   var inti = 0;
                   var queryTask = new esri.tasks.QueryTask("http://dell-pc/ArcGIS/rest/services/SirenFeatureService/MapServer/3");
                   var query = new esri.tasks.Query();
                   query.returnGeometry = true;
                   query.outFields = ["SIREN_NO", "Reg_E", "ObjectID"];
                   if (intCondition == 0)
                     query.where = "1=1";
                  else if (intCondition == 1)
                     query.where = "Reg_A=" + strRegionName + "  " + "And" + "   " + "City_A=" + strCityName;
                     queryTask.execute(query, function (results) {
                      for (var i =0; i < results.features.length; i++) {
                         featureAttributes = results.features.attributes;
                         items.push(featureAttributes);
                         var memStore = new Memory({data: items,idProperty: "ObjectID"});
                     window.grid.set("store", memStore);
                     window.grid.set("sort", "Reg_A");
i have check my code works and fullfill items array.but i think the problem starts from the red lines.please help why grid is not showing data.thanks for help
YousefQuran
        بسم الله الرحمن الرحيم
Dear Nadir,
The problem is not clear, but I think it is better to use dgrid in this way. It will handle data easily but you have to make sure about passing fields because it is case sensitive and do not change the "id" column name because the theme will not works fine.
I wish this help,
Regards.
