Does this sample work with SDE?
1777
06-27-2013 08:44 AM
JoseSanchez
Hi all
I just downloaded this sample and I would like o make it work with SDE
http://developers.arcgis.com/en/javascript/samples/ed_simpletoolbar/
It only shows the attributes of the seelcted featreu but I can not digitize a new polygon or remove it
Thanks
JohnGravois
this sample works with an ArcGIS Server Feature Service, which means that SDE data was used to publish a map service with feature editing capability.
JoseSanchez
Do I need to version the SDE layer that is going to be edited?
JohnGravois
no.
check out this article from the same section of the help i linked before for more info.
JoseSanchez
Does it work with 10.0 or do I need 10.1?
JohnGravois
the published sample you mentioned is already pointing at a machine running version 10.0 of ArcGIS Server.
